Smokstak Down Under
2 Worthington steam pumps
Hello All l recently bought 2 pumps but both are missing parts, details below: No. 1 5 1/4...
this thread has 5 replies and has been viewed 256 times
Old 08-02-2009, 05:57 AM
Walky Walky is offline
Default 2 Worthington steam pumps
Hello All
No. 1
5 1/4 x 3 1/2 x 5
Patented Apr 4 1889
Military Arrow head marking
- missing valve gear and valve block
No. 2
4 1/2 x 2 3/4 x 4
Patented Apr 4 1889, Sep 18 1900, Oct 29 1901, Sep 30 1902
SNo 159413
- missing all pistons and rods
Any guesses as the age of each pump?
l am thinking No. 1 is over 100 years old due to the patent dates
Pump No.2 could be 1940s or '50s??
Walky
Old 08-02-2009, 07:07 AM
Default Re: 2 Worthington steam pumps
l should have mentioned that l am looking for spares, engineering drawings and manuals
Fair chance that l will have to make the parts though
Walky
Old 08-02-2009, 11:31 AM
WilliamInOz WilliamInOz is offline
Walky,
have you opend up the pump side to see if it isnt swiss cheese and to see if there is anything missing.
You'll need a decent air compressor to kick it over too.
drain cocks etc you can get from a person in QLD he it in the back of the tomm mag but they arnt that hard to make or any fittings as long as they do there job everythin it hunky dory well sort off
Cheers, Will
Old 08-02-2009, 11:34 AM
have you got any pictures too mate?
Cheers, Will
Old 08-03-2009, 01:14 AM
Hey Will
So far it all looks OK, nothing unexpected.
No. 1 pump water cylinders have brass liners and steam cylinders are good - got 1 side freed up without too much drama.
No. 2 pump steam cylinders are good and steam valves are in working condition, l have not had the pump head off yet.
l should be able to work out the dimensions of the missing parts by scaling the dimensions from one pump to the other
- some manufacturers drawings would still be great though
Thinking about trying to cast some of the parts at home in aluminium like:
- piston blanks, need 4 for No.2
- valve block, valve arms, valve pivot stand for No.1
The rest l could fabricate in steel
Thanks Walky
Old 08-03-2009, 07:16 AM
the only thing that will come close to mechanical drawings is cut away sections.
Cheers, Will
Schematics/information on Hall Steam Pumps Reeves1917 Stationary Steam & Traction Engines 1 05-08-2009 12:29 PM
Looking for Schematics-any information on Marsh Steam Pumps Reeves1917 Stationary Steam & Traction Engines 3 04-20-2009 12:06 AM
Worthington steam pump WilliamInOz Stationary Steam & Traction Engines 48 04-08-2009 06:35 PM
Rare steam pumps WilliamInOz Stationary Steam & Traction Engines 0 12-13-2008 11:25 AM
Steam Fire pumps William Murnahan Stationary Steam & Traction Engines 8 08-03-2004 02:49 AM
