18-32 Crossmotor Case and 45 K-A Chamberlain
I have a 18 -32 Crossmotor Case which I am about to start to restore. I also have access to a 45...
this thread has 6 replies and has been viewed 556 times
Old 08-02-2009, 07:48 AM
RickAus RickAus is offline
Default 18-32 Crossmotor Case and 45 K-A Chamberlain
I also have access to a 45 K-A Chamberlain, which I have to go and collect.
I would appreciate any information about the Crossmotor Case, particularly workshop manuals and operation manuals.
The Chamberlin is more for my Aussie mates
I have to go and get it from this guys property my dad found it about 8 years ago and was going to get it but got crook and eventually ended up selling all his tractors.
My question is, what is it worth, it is in going condition but the steering box is stuffed.
Grateful for any help, or info
Cheers,
Rick
Old 08-02-2009, 10:33 AM
JD Canuck JD Canuck is offline
Default Re: 18-32 Crossmotor Case and 45 K-A Chamberlain
We found a manuals for our 18-32 at http://www.ytmag.com/cgi-bin/store/mansrch.pl
Old 08-04-2009, 05:37 AM
Richard Sturdy Richard Sturdy is offline
Rick, I have an 18-32 K, which I bought last year. Apart from shot manifolds (repros are available from Rosewood) the biggest problem with these old tractors is wear in the final drive/differential/rear axle assembly. Mine needed loads of work, including cutting a new drive pinion and we had to have the axle metal sprayed and re-machined back to standard. The Hyatt baerings can also be a problem etc etc etc..... All this is often caused by the fact that the final drive casing is very low-slung and subject to damage in use, which can allow all the lubricant to leak out without the operator ever realising the fact until the damage is done. By this time, the final drive is usually shot, resulting in many such tractors subsequently being used only for stationary belt work until the end of their useful lives. You may be lucky and have a good one, but they can be expensive to fix if they are like mine was. However, when you get them right they are lovely old tractors. Good luck.
Tricky Dickie
Old 08-04-2009, 05:41 AM
David Parfitt's Avatar
David Parfitt David Parfitt is offline
Rick,
Might be worth asking about the Chamberlain on the Aus/NZ section of the forum here:
http://www.smokstak.com/forum/forumdisplay.php?f=115
All the best
David
www.steel-wheels.net
Old 08-04-2009, 06:53 AM
Thanks for all the great info Didnt even realise there was a Aus/NZ section
When I was a kid I used to drive the 18-32 in tractor pulls I dont remember any problems with the final drive then it used to run fairly well.
Dad was going to do it up and started to pull it down and got pretty crook and ended up selling all his tractors boy i wish i had them all now
Any way he kept the case did nothing with it now i went and got it and want to restor it needs a bit of work though
Again thanks for the info will send som pics soon
cheers Rick
Old 08-26-2009, 08:52 AM
Harry Henderson Harry Henderson is offline
Rick, Just wondered what serial number your Case is. I have an 18/32, serial 60267. The tractor spent its working life in Australia before it was brought over to England in the early 1980's. wondered if they where closely matched. Great tractor though, no shortage of power, they just make more noise! In the end the whole county can hear what you're doing! Great Stuff! Harry
Old 10-22-2009, 07:51 AM
Photo Re: 18-32 Crossmotor Case and 45 K-A Chamberlain
Hi Harry,
Sorry it has taken so long for me to reply. Here are photos of the ID plates on the tractor.
Name:	ID plate small.jpg
ID:	65416   Click image for larger version
Name:	Plate small.JPG
Case 22-40 crossmotor help Steve Thole Antique Tractors - Old Iron Lugs, Cleats and Tracks 43 10-08-2009 01:33 PM
Case 12-20 Crossmotor Harry Antique Tractors - Old Iron Lugs, Cleats and Tracks 6 09-01-2008 12:58 PM
Crossmotor Case Glenn Gieszler Antique Tractors - Old Iron Lugs, Cleats and Tracks 1 07-04-2005 12:43 AM
10/18, 12/20, 15/27 Crossmotor Case Tractors Jerrod Werth Antique Tractors - Old Iron Lugs, Cleats and Tracks 4 03-29-2005 08:17 PM
Crossmotor Case Craig A Antique Tractors - Old Iron Lugs, Cleats and Tracks 3 03-15-2005 02:01 AM
[IMG] code is Off
