steam tractor coming out of gearhi all, i have a wilesco d40 steam tractor. when i run the tractor, the gear that rides on the axel...this thread has 1 replies and has been viewed 358 times
hi all, i have a wilesco d40 steam tractor. when i run the tractor, the gear that rides on the axel (connected to a metal handel),that makes it go into neutral and normal, keeps coming out when the tractor starts running, so in order to keep the wheels moving i have to hold it in place. is there a way to bend it so it wont slip off?
serious suggestion, put a little bit of some silicon sealant or even contact cement (Welder or E-6000 type stuff) in the interface between the two parts of the shift lever to make it stiffer. Alternate suggestion, pop the axle cap off, remove the wheel and squish the rivet a bit with channel locks or vice grips. Tertiary suggestion, order a new shift lever, drill out the two pop rivets and replace.
Option 1 takes 30 seconds, option 2 about 2 minutes, option 3 takes about 10 or so and costs about $20..... take your pick
| Aumann's Album Casting A Pinion Gear for 50 HP Steam Tractor | DanBoom | Stationary Steam & Traction Engines | 0 | 07-08-2009 12:26 PM |
| Little Giant Wagner lawn tractor steering gear? | Rene Elliott | Garden Tractors / Mowers / Scooters | 9 | 03-12-2009 12:44 PM |
| Ward/Simplcity garden tractor gear hub | will s | Garden Tractors / Mowers / Scooters | 2 | 08-17-2008 10:11 AM |
| Tractor,steam, parts, trucks,& misc. Auction coming up | Andrew Yeary | Auctions of Engines, Tractors and Old Iron | 0 | 06-16-2008 10:13 PM |
| Steam Train coming to South Carolina! | Polaraman | Stationary Steam & Traction Engines | 1 | 09-01-2007 04:14 AM |
