Mep002a or 3a Voltage Regulator
this thread has 2 replies and has been viewed 1489 times
Old 08-06-2009, 10:55:57 PM
808Donald 808Donald is offline
Smile Mep002a or 3a Voltage Regulator
After working my way through the new to me canabalized MEP engine, (no button in fuel pump, wrong shimstock, governor stop pin missing on gear cover, missing filter cans) I hooted and enjoyed the sound of the big bore Onan as she came to life. Much to my dismay the generator end was not working either. I was able to narrow it to the voltage regulator by following the directions in the 003a tech manual.
My question now is, should I try to repair the reg or find another one? Any advice from mep enthusiasts?
Old 08-09-2009, 02:04:11 PM
Raymond Raymond is offline
Default Re: Mep002a or 3a Voltage Regulator
Repair it. It's nothing but Radio Shack components and the manual lists all of them. Check the little voltage transformers that power and feed back to the regulator. Disconnect the regulator and flash the field. It should go to 300 volts and shut down on over-voltage. If not the problem is in the generator or exciter section.
Old 08-10-2009, 12:41:32 PM
Thanks for your help!
With Hurricane Felicia bearing down on us,I am going today to see my electronics friend about checking the regulator. My electrical experience is limited to low voltage.
Voltage Regulator Bill Geyer Generators & Motors General Discussion 4 09-07-2009 04:16:39 PM
Voltage regulator philthecoal Generators & Motors General Discussion 0 07-02-2009 05:05:46 PM
Help with Ext. voltage regulator JHFoster Small Air Cooled Gasoline Engines 11 05-25-2009 02:05:05 PM
Need help with voltage regulator oldtool53 Generators & Motors General Discussion 13 12-11-2006 10:04:20 PM
Need Voltage Regulator PFT Generators & Motors General Discussion 24 09-03-2006 08:52:27 PM
