Smokstak Down Under
Ronny Restoration
Hi all, as you know i got a couple of ronnies the other week. Im going to start on Pops 1946 ronnie...
this thread has 31 replies and has been viewed 879 times
Old 08-07-2009, 09:29 PM
WilliamInOz WilliamInOz is offline
Default Ronny Restoration
Hi all, as you know i got a couple of ronnies the other week. Im going to start on Pops 1946 ronnie first.
Now im kinda flying a bit blind but also am after a copy or photocopy/scan of a ronny N manual.
Cheers, Will
Old 08-08-2009, 04:37 AM
Default Re: Ronny Restoration
Update:
Got the hopper off to have bit of a spring clean. I'm toying with the idea of electrolis or something along these lines.
Cheers, Will
Old 08-08-2009, 08:03 AM
Walky Walky is offline
Will
Got one at home for my Ronny N, drop me a line
Walky
Old 08-15-2009, 05:46 AM
got the hopper off today for a derust inside.
I was supprised how easy it came off!
Cheers, Will
Old 08-26-2009, 05:49 AM
Default Re: Ronny Restoration UPDATE
Hi all,
cleaned the bottom out of all the crap and gunk put a dash of diesel through the spark plug hole.
but have got a problem with the maggie, its got a weak spark but might need to get some pint files to clean up the connections.
Its got good compression and the rings are fee and doing what there supposed to be doing.
Next thing is to start on the transport!
Cheers, Will
Old 08-26-2009, 08:02 AM
steeleye steeleye is offline
Give the points a good clean and set the gap to about 12 thou. or as my manual states "the thickness of two Gillette Blue Super razor blades" . Pour a little petrol in the plug hole and put the plug back in. Give the crank some good whirling. It should fire with a bit of luck. The smirk or grin is had to get rid of for a while. Savor the moment and pat yourself on the back and celebrate.........best of luck......Phil
Old 08-26-2009, 11:42 AM
steele eye it must of had maggie issues in the past since the metal part is bent over heaps. I'll go and find some point fills tomorrow. i wonder if the young people like me know about these things or corner the oldest fella in the shop maybee
Hmm you should see my smile when it fires up in the steam area
Cheers, Will
Old 08-26-2009, 07:57 PM
Gday Will. Am curious as to which type of maggie you have? I know of two types of Lucas maggies that the Ronnie "N's" had. The RS1 and the SR1. Which one is yours? What is the "metal part bent over heaps"? I've got one sitting on our dining table at the moment. Looks a bit like a small loaf of bread with a round disc cover on one end that covers the points!..............Cheers Phil
Keepum burnin an turnin
Old 08-27-2009, 02:10 PM
Ill get a pic of it off pops ronny the and the other one i got at the same time.
Cheers, Will
Old 08-27-2009, 07:29 PM
E27N's Avatar
E27N E27N is offline
Will check your condenser my SR1 on the sunbeam was the same it sparked but weak.(TIP) one from a holden 6 dizzy fits ....just and work like a charm. Can't wait to see some pics.
Old 08-28-2009, 06:32 AM
Will
There are a couple of R&T N type mufflers on eBay at the moment.
One is an original with 1 1/4" thread, the other is new with 1" thread.
l think the new one is more likely to suit your engine.
Does any one know if the R&T mufflers were made in that cannister shape with 1 1/4" threads and what size engine did they go on?
Walky
Old 08-29-2009, 02:04 AM
I've got one on my 4hp Ronnie "N" and it is original. Dont know if they were on other models of Ronnie/T though.........Phil
Old 08-29-2009, 06:20 AM
Photo showing hopper just been taken off
spark plug taken out oil is slowly drainin out, so i chucked 1/2 a jam jar of diesel down to get everything freed with the rings.
Cover plate off to have a look to see what it was like inside.
the bore, looking up from underneath
Cheers, Will
Old 08-29-2009, 06:23 AM
looking at a bit of the piston
now the maggie! i know jack diderly squat about these ones
photo 1
photo 2
Cheers, Will
The Following User Says Thank You to WilliamInOz:
Old 08-31-2009, 06:25 AM
Will
there is a Ronny N piston & conrod on eBay
might suit your engine, check the manual for part numbers
the smaller engines shared a lot of parts
Walky
Old 08-31-2009, 07:22 PM
E27N's Avatar
Hey Will, Is it just me or does your Ronny and my Sunbeam/Cooper look like they are, well nearly the same bar some minor differences like the bore casting, flywheels and fuel tank??????
Old 08-31-2009, 08:50 PM
Eric Schulz's Avatar
Eric Schulz Eric Schulz is offline
Andrew, as far as I know, there are few interchangeable parts between the R-T N and the Cooper/Sunbeam X. I don't think I would agree about minor differences. The only part that is N looking is the crankcase and crankshaft, everything else is different. Although I have not checked this, I would think these engines came from the RB&T factory, unlike other Cooper models.
Eric
Old 09-01-2009, 06:56 AM
the 2hp conrod part number is V161 and 3hp on is V409
Old 09-01-2009, 07:14 AM
Hi adrew,
i think there both similar but how shaw im about this i dunno. Im more into steam than oil engines.
Cheers, Will
Old 09-01-2009, 09:36 AM
E27N's Avatar
Cheers Eric that's why I asked to question I have a derelict Engine sitting in my collection that I can't identify (don't panic i will post pics) that is similar in the same respect but something in the back of my head is telling me that austral???? also made a similar looking engine but i could be way off kilter!
P.S: Being at the tender age of 23,recalling engine makes from back in the day isn't something i have at my disposal
P.P.S: sorry to hijack Will !
Cheers Andrew
Ronny tractor serial numbers WilliamInOz Smokstak Down Under 31 11-19-2009 09:28 AM
Oddball Piece Restoration Nearly Complete, Serial Tag Restoration Question bryani289swmi Small Air Cooled Gasoline Engines 2 04-15-2008 01:10 PM
I.D. Tag restoration Sean B. Small Air Cooled Gasoline Engines 2 02-20-2006 04:15 PM
Restoration Ed Welsh Antique Engine Archives 0 02-26-2003 03:59 PM
Restoration Don Oberholtzer OHIO Antique Engine Archives 0 03-09-2002 03:33 PM
