Smokstak Down Under
Champion Spark Plug Cleaner & tester
Hi All Restored this earlier this year as something different to do, does anybody know how to date...
this thread has 6 replies and has been viewed 582 times
Old 08-17-2009, 07:51 AM
Rusty Engines Rusty Engines is offline
Default Champion Spark Plug Cleaner & tester
Hi All
Restored this earlier this year as something different to do, does anybody know how to date it the only date I could find was a next test date tag on the power cord which said ‘next test date Aug 63’
It also works fine
Ian
The Following 3 Users Say Thank You to Rusty Engines:
Old 08-17-2009, 08:04 AM
Oldsiron's Avatar
Oldsiron Oldsiron is offline
Default Re: Champion Spark Plug Cleaner & tester
Hi Ian, Is the sign original? I have a metal champion sign the same and it has a date in the lower corner 1962. this might help you date it if the sign is the original one of the cleaner.
I can see something in the lower right corner, is it a date
chris
Old 08-17-2009, 08:31 AM
Hj Chris
Is the sign original? don't know
On the lower right corner is 'PS105' most likely the code for the sign
Ian
Old 08-17-2009, 10:34 AM
Ironsides Ironsides is offline
Ian,I also am in the process of overhauling one of these little beauties.Where did you get the bits and pieces to rebuild or is it not as difficult as it appears when you open it up ?Bye for now,Norm
Old 08-17-2009, 04:32 PM
hottube's Avatar
hottube hottube is offline
Thumbs up Re: Champion Spark Plug Cleaner & tester
Your restoration, looks great!!!
Old 08-18-2009, 07:16 AM
Hi Norm
The two mirrors were broken, the air regulator stuck, none of the threads wanted to undo, and all the wiring and rubber hoses had to be replaced
I was lucky the buzz coil worked and the sand bag and nozzle were fine other than that all it needed was a good paint job
Ian
The Following User Says Thank You to Rusty Engines:
Old 09-13-2009, 06:10 PM
Bob Gibson Bob Gibson is offline
We have had a lot of laughs with those machines, we would run a wire from the tester to a spanner, just out of reach of the pit, i would ask someone to pass the spanner, while my mate who was leaning on the machine pressed the button, we attached the wire to pens, all sorts!in the end no one would take their hands out of their pockets.lol
good memories, regards Bob
Champion # 34 Spark Plug Gap Lou Quirch Antique Gas Engine Discussion 2 04-01-2007 01:03 PM
Spark Plug Tester Jim H. Antique Engine Archives 2 06-18-2004 08:12 PM
Spark plug tester Andrew Antique Engine Archives 0 01-01-2003 08:29 PM
CHAMPION OLD/NEW SPARK PLUG HELP BILL RING (FLA) Antique Engine Archives 3 04-11-2002 12:46 AM
Spark plug cleaner KEN Fall Antique Engine Archives 2 03-22-2001 11:11 PM
