Steam Engines
Steam Engine Restoration and Repair
this thread has 5 replies and has been viewed 5759 times
Old 08-17-2009, 05:37:23 PM
SteamLoco726 SteamLoco726 is offline
Default Steam Engine Restoration and Repair
Just wanted to show off Dad's shop. We've been in the machine shop business since about 1975. We're located in Eaton, OH. Steam engines have always been a part of our family. Our fathers and grandfathers are our mentors. We have occasionally repaired engines but most of the restorations have been our own projects.
Thanks,
The Following 12 Users Say Thank You to SteamLoco726 For This Post:
Old 08-17-2009, 05:52:52 PM
Beth V's Avatar
Beth V Beth V is offline
Default Re: Steam Engine Restoration and Repair
Andrew,
Where are the photos of the Baker restoration?? How much needs to be done to swap the boilers, etc?
Beth
Old 08-18-2009, 12:53:40 PM
I'll try to use this thread for the Baker restoration. We've been busy with shows so it's been on hold.
We're currently replacing the flues in a half scale engine that is suppose to go to a show in September so that is at the top of the list currently.
Thanks,
The Following User Says Thank You to SteamLoco726 For This Post:
Old 11-30-2009, 11:24:05 AM
A quick update: the model is all finished. We replaced the small half inch pipe plug (that was stuck) with a 3/4" pipe plug, welded up the bottom section of the flue sheet (since we were already welding in the tank bung for the 3/4"plug). Then we replaced all the flues and rolled and installed a new bottom section of the smoke box. I have several pictures that I will add ASAP
The Baker:
We have most of the Baker disassembled. We have been amazed at the condition of everything that we hace taken apart. The crank pin still shines like chrome! All the pet cocks are free(turn easily with your fingers). The cylinder is like a time capsul. Upon removing the cylinder head there was no rust It looked as clean as an engine that would've run this year. Once broke loose the packing gland nut for the piston rod unscrewed by hand. This engine spent it's very short working life heating a mill pond in Michigan. I don't believe that it ever ran anything under load. All of the babbit bearings in the valve linkage still have the marks in them from casting against a newly turned shaft (0 wear). So far we have been very pleased. Disassembly continues and should be completed shortly. We welcome anyone who wants to stop by and visit/take a tour
Pictures coming soon.
Andrew Kramer
The Following 3 Users Say Thank You to SteamLoco726 For This Post:
Old 12-04-2009, 05:42:09 PM
In this picture you can sorta see how thin the pipe coupling that was welded to the flue sheet for the clean-out plug was getting.
Old 12-04-2009, 06:04:45 PM
First breath of fresh air!
This is a view through the hand hold above the firebox. Yes there is a little dirt/scale but other than that it looks new!
This last picture sort of shows the delima we have with the paint scheme. What ever Dad decides is ultimately what it will be. It appears that it was repainted at the factory. I've never seen another Baker that had green pinstripes on top of red paint. It appears that it was painted blue and yellow first then red and green. Due to the fact that the pinstripes are right on top of each other it leads one to think that it was repainted by the same person or crew.
The Following 7 Users Say Thank You to SteamLoco726 For This Post:
Whats the skinny on B&B Steam Restoration Dan Dyman Steam Stationary Engines, Traction Engines, Steam Boats 9 08-05-2015 11:22:22 PM
steam gauge repair tool Peter Steam Stationary Engines, Traction Engines, Steam Boats 12 03-14-2014 09:44:47 AM
Steam Traction Engine Club Restoration Projects Jeff Smith Steam Stationary Engines, Traction Engines, Steam Boats 10 06-04-2008 12:50:06 PM
Baker Steam Traction Engine Restoration JKKD Steam Stationary Engines, Traction Engines, Steam Boats 50 05-27-2007 11:12:14 PM
Kohler k 91 restoration/ gas tank repair Mac Leod Small Air Cooled Gasoline Engines 10 02-03-2007 12:29:40 AM
