Lyndes patent gas plant info wantedI have a the remains of a Lyndes patent gas plant. This plant would have produced gas from petrol...this thread has 8 replies and has been viewed 258 times
I have a the remains of a Lyndes patent gas plant. This plant would have produced gas from petrol (gasoline) and used a small Robinson hot air engine and roots blower to pressureise the gas.
I believe that most of the pipework is there but I`m missing the engine and blower. I have already located the correct size of hot air engine but I have no idea about the Roots blower. Can anyone help? Mike |
Here is a british colonial that just sold last weekend from Lowell Wagoner if it helps any
These are two different Robinson engines with producer gas pumps mounted on the front, but they are piston type pumps not roots type pumps.
Thanks guys, Is the blower with the coloinal plant a roots?
Mike |
yes, it appears to be, it would have to rotors in the cast iron housing with most likely three impellers on each rotor that engage each other in opposite directions to pump air just like a blower on an older Detroit Diesel Engine
yes, it appears to be, it would have to rotors in the cast iron housing with most likely three impellers on each rotor that engage each other in opposite directions to pump air just like a blower on an older Detroit Diesel 2 cycle Engine. See this picture
http://www.jagweb.com/aj6eng/roots_action.jpg |
The Following User Says Thank You to BTurney:
Any idea where to find one of these blowers? Are Roots still active?
Mike |
Hi Mike,
for the Roots blower go to the Beaulieu Autojumble 12 and 13 september, I have seen these blowers sometimes there. Anton |
The Following User Says Thank You to Anton van der Cruijsen:
Hi Anton,
It`s good to hear from you!!!! Thanks for another good Nuenen, hopefully I`ll put the Benz forward in the workshop and bring it to you next year. Are you going to Dorset this year? I`m taking my steam roller there this year, maybe I`ll see you there. Mike |
| Kohler 3A21 Electric Plant Info wanted | Jeff DeCoe | Auctions of Engines, Tractors and Old Iron | 0 | 09-07-2008 02:22 PM |
| Info on York Engines prior to Patent granted | BarryH | Antique Gas Engine Discussion | 6 | 02-12-2008 12:41 AM |
| F-M Type Y, Style VA Power Plant Wanted | edurand | Generators & Motors General Discussion | 2 | 08-17-2004 11:36 AM |
| KER-O-EL light plant wanted | Will Cummings | Generators & Motors General Discussion | 0 | 10-04-2000 09:07 PM |
