Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
What year is this continental engine?
Does anybody have a Serial Number List for Continental Red Seal Power Units? I have a model No....
this thread has 5 replies and has been viewed 301 times
Old 08-20-2009, 12:31 PM
Steve V.'s Avatar
Steve V. Steve V. is offline
Default What year is this continental engine?
Does anybody have a Serial Number List for Continental Red Seal Power Units? I have a model No. GRA-589 with Serial No. 127724 and would like to know what year it was built.
Name:	Red Seal Continental - Rockford PTO (2) (Large).jpg
Old 08-20-2009, 02:06 PM
Default Re: What year is this continental engine?
Uhhhh...where on your rig does the GRA-589 appear???
John was probably at least partly asking for casting #'s as GRA isn't a familiar Cont designation...
Cont had some old G's: G, GA, GB in the teens, all 4cyl's, and a later set of G's: G, GD and GF, again all 4's, but no GR, as far as I've found, and none as large as 589 (Cont numbers are often the cid)...
I don't pretend my engine lists are complete, especially with Cont; let us know where the GRA 589 appears, and if on an ID tag anything else it shows.
Whatever the 589 means, it's apparently not the cid, judging by the pic...
The Following User Says Thank You to Bud Tierney:
Old 08-21-2009, 10:39 PM
Steve V.'s Avatar
Thanks for the help you guys...OK, I think I have the correct information now. I cleaned up an aluminum tag on the Engine that is stamped "F162 99069". In the block casting it looks like the digits "L2W" . Do any of these numbers indicate the year built?
Old 08-21-2009, 10:56 PM
I am working on some of that. F series the most common Continentals. They were made in 3 sizes F 124, F 140 & F-162. Used by many many OE manufactures. Parts are plentifull. The 6 cylinder F series came out in the mid to late 1930's
The Following User Says Thank You to John Schwiebert:
Old 08-24-2009, 02:17 AM
Dempster Dempster is offline
Try asking someone at Wisconsin Motors:
http://www.wisconsinmotors.com/
Or contact Warren Moon at Montes Equip.
http://www.montesequipment.com/
The Following User Says Thank You to Dempster:
Old 08-24-2009, 11:19 PM
Steve V.'s Avatar
Thanks for the 2 links. I got the info right away at "Montes" , very helpful
What year is this continental engine? Steve V. Antique Gas Engine Discussion 2 08-20-2009 12:45 PM
Continental engine Avery 5 Ton Antique Autos and Trucks 8 03-15-2009 11:10 PM
85 hp Continental Gin Engine farmsc Vintage Diesel Engines 1 09-29-2008 11:25 PM
Value Of A Continental Y-69 Engine Rod Krehbiel Antique Tractor Talk 6 01-23-2008 09:23 AM
Continental engine Chris McMasters Antique Engine Archives 0 09-29-2001 11:47 PM
