An Electric starter on a IHC LA ???Yes, I put it on this engine. I have seen several LA and LB IHC engines hooked up to car...this thread has 6 replies and has been viewed 514 times
Yes, I put it on this engine. I have seen several LA and LB IHC engines hooked up to car alternators for battery charging. I went one step beyond and made mine electric starting and charging. Works very well. What you are seeing here is the "maiden voyage" of this unit. Now I'm gonna get things sreamlined and usable....http://www.youtube.com/watch?v=Zm64yjd-e38
"May your walk through life have no dogpiles in it" -Brian Lynch |
The Following 4 Users Say Thank You to Brian Lynch:
Schweet! I plan on doing that myself...one of these days.
J.I.M. |
Brian,
Please publish a schematic and parts list for your electric start/charge system. Thanks |
Ok fellas, I will draw up the electrical schematic and parts I used for this later and post it here for all to enjoy
-Brian
The Following User Says Thank You to Brian Lynch:
Brian:
I've tried the same thing with my Homebrew Hvid engine with mixed results. It cranks fine but doesn't charge worth a hoot. My first brief checkout when I got the Delco unit found it to be in what appears to be good electrical condition. As it is, I made a pulley and cranked up the engine so the starter/generator was running at about 5,000 RPM and it would only make three amps, full field (field grounded). As it was, the field drew about 1.3 amps so the net charge was only about 2.7 amps. I'm gonna have to take it off and tear it down again and look for armature shorts, etc. Nice looking rig. Take care - Elden ![]() http://www.oldengine.org/members/durand/ |
The Following User Says Thank You to Elden DuRand:
Ok fellas! As requested, an electrical schematic diagram for a simple starter generator combination. As for a parts list, I used a short length of light angle iron, a 4L530W belt from Napa, a few bolts and nuts, and an old adjustable alternator bracket from a car. The reason you see two pix the same is because of camera flash. This way you can see each diagram clearly. The upper diagram is a complete system for use with a battery coil ignition system with timer. The lower diagram is the one used in my setup and will be the most commonly used as LA and LB engines use a magneto in place of a batt./coil. If you have any questions throw me an email and I'll help all I can.
The Following 2 Users Say Thank You to Brian Lynch:
| Gas to electric h&m conversion or electric "replica"? | newuser | Antique Gas Engine Discussion | 0 | 02-15-2009 06:42 PM |
| Q Gen with Starter | SBreeden | Small Air Cooled Gasoline Engines | 8 | 01-18-2009 02:35 PM |
| T40 starter | Hoodeleydoo | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 1 | 08-26-2008 11:48 PM |
| Starter for DJC | William Snyder | Generators & Motors General Discussion | 9 | 09-03-2006 02:35 AM |
| Need Electric Starter | WilliamR | Kohler Generators | 3 | 07-06-2005 10:01 PM |
