eBay Auctions
Go Back   SmokStak > SmokStak® General Discussion > Craigs List / eBayŠ Auction Discussion
Questionable steam engine
I was looking through ebay and found this steam engine and it doesn't look like any conventional...
this thread has 5 replies and has been viewed 558 times
Old 08-22-2009, 02:13 AM
Connor S. Connor S. is offline
Default Questionable steam engine
I was looking through ebay and found this steam engine and it doesn't look like any conventional slide steam engine i've seen and im little confused on what it is
http://ebay.com/ws/eBayISAPI.dll?ViewItem&item=150366452437
if anyone could give any info it would be great
Connor
Old 08-22-2009, 02:19 AM
Default Re: Questionable steam engine
Oh, two more things, one i meant slide valve, second i emailed the guy and he said his grandfather used it for work, although he wasn't exact on what it was used for.
Old 08-22-2009, 10:02 AM
It looks like an unfinished model hit & miss engine. I don't know the make. If you look at the first picture through the flywheel to the other side you will see a brass bushing with nothing in the hole. I think that this would be where the shaft for the gear/cam would be mounted. Missing one governor weight , push rod , latches , gear on crank shaft ?? , carb. ?? , Muffler , and who knows what else. It's more than I can handle , even if I had the prints. Ron
Old 08-22-2009, 11:38 AM
ssimntih's Avatar
ssimntih ssimntih is offline
Images: 50
and thats not to say the engine was never finished due to a mess-up in the machining or something, looks like a shelf queen to me.
Old 08-22-2009, 01:02 PM
Exclamation Re: Questionable steam engine
Looks like possibly a F/M 'N' kit. Nice model, but you have to finish it
Old 08-22-2009, 04:22 PM
thanks guys i knew it didn't look like a steam engine, and it more resembled a hit n miss engine, but there was a huge amount of parts missing. It's in sacremento, and it's only 2 hours away and if I could get the engine for cheap it would be very good for parts.
1912 Case steam traction engine 60 hp live steam on eBay John Faccin Stationary Steam & Traction Engines 30 11-19-2009 12:26 PM
1880's Herschell Spillman steam carousel w steam engine on Ebay JKWidener Stationary Steam & Traction Engines 1 05-30-2009 08:36 PM
21st century steam Screw type steam engine renewablejohn Stationary Steam & Traction Engines 1 03-29-2009 09:05 PM
Williams Grove Historical Steam Engine Assoc. Steam School M Zeigler Stationary Steam & Traction Engines 7 06-10-2008 08:51 PM
Moving a tractor with a questionable front axle 6point9diesel Stationary Steam & Traction Engines 3 02-23-2008 11:54 AM
