Sumbeam XD won't startit's got me stumped good fuel, good spark when earthed out on the head heaps of compression but no...this thread has 13 replies and has been viewed 344 times
it's got me stumped good fuel, good spark when earthed out on the head heaps of compression but no go. Timing hasn't been touched since it last ran in the 70's
Will post pic when it lets me for some reason It won't let me post pics in antique engines and here in the same session
yup tried that to
If its got fuel, compression and spark,timing it will go. One of those things is letting you down.My Dad run one of those for years on a shearing plant. He can give a few hints. Call in at our stand at Dowerin (291) and ask.
The Following User Says Thank You to Ray Freeman:
It could be the magneto. I have had maggies that have an ok spark with the plug sitting on top of the engine but just don't seem to throw a strong enough spark under compression.
The Following User Says Thank You to Patrick M Livingstone:
Hi E27N,
I have no idea what a sumbeam XD is. I had an N series R&T driving a saw bench. I hadn't used it for awhile, good spark, new plug, fresh fuel, and compression when I turned it over slowly - wouldn't start. I eventually worked out the inlet valve was sticky on the stem and lagging behind at cranking speed. A bit of oil and off she went. Might be your problem. Regards, Wayne www.bluefuel-whitesmoke.com |
The Following User Says Thank You to Wayne Timms:
Ray I'd love to get to Dowerin this year BUT the call of duty at HNS is stronger unfortunately Newdegate maybe??? ours is off the shearing plant as well I have photos under the heading "flutter choke orientation" on the antique board. Wayne and Pat I have just relapped the valves so they are good but I think Pat has hit the nail on the head the mag is too weak to spark under compression I know a guy that can remagnetize locally so i'll call in a favour methinks. cheers Andrew |
When all tuned up nice and fitted with the muffler that was on the shearing plant they are all but silent. A sweet running engine. I have one here and I need to get the mag done as well. They are a similar engine to the Ronny N. They have more modern shaped castings and a different carby.There were also lots used on 32 volt lighting plants.
What happens if you drop a little petrol into the cylinder through the plug hole ?
See ya, Graham |
How many times has that got us going! I did get a bit carried away with the drop bit years ago and burnt a Villiers on a cement mixer.Set up at Dowerin today. Looks like a good field day this year. Tracmach were setting up a decent display with some running engines as well as the tractors and trucks. |
finally got around to taking more pics plus the view from my shed ![]() Last edited by E27N; 08-25-2009 at 07:34 PM. Reason: Add piccy's |
IT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
capacitor was gone, replaced it and the spark went from a dull mangy looking thing to a fat blue one it fired first turn!!!!! I'll post a vid when i build a fuel tank. |
Check to see if the spark lines up with the mark on the flywheel. Magneto can be fitted in 2 positions 180 degrees apart.
John Cooper |
cheers john this one has a little pin that lines up on the coupler to prevent that .
http://www.smokstak.com/forum/showthread.php?t=64997 |
| IHC 6hp M Won't Start | mongansmachine | Antique Gas Engine Discussion | 40 | 07-04-2009 11:40 AM |
| trying to start a W2C, no go so far | werfymmot | Onan Generators | 3 | 04-17-2006 03:15 PM |
| IHC M won't start | Ihorse | Antique Gas Engine Discussion | 7 | 07-03-2005 11:18 AM |
| How to start a TD-14 | Gasengin | Antique Tractor Talk | 2 | 05-12-2005 12:23 PM |
| Can't start it | Tim Williams | Antique Engine Archives | 0 | 01-21-2003 09:27 AM |
