Smokstak Down Under
Sunbeam Video
short Vid of the sunbeam running tonight. Yes there is water in the head.;) ...
this thread has 15 replies and has been viewed 390 times
Old 08-27-2009, 10:00 AM
E27N's Avatar
E27N E27N is offline
Default Sunbeam Video
http://www.youtube.com/watch?v=OhWV62mCOLE
The Following 3 Users Say Thank You to E27N:
Old 08-27-2009, 01:05 PM
Ironsides Ironsides is offline
Default Re: Sunbeam Video
Shore on those machines over the years,I feel you may have her running a bit fast-----could perhaps be the exhaust noise as they were a very quiet motor when muffled correctly.Good to see it running,well done Norm
Old 08-27-2009, 07:22 PM
E27N's Avatar
yeah more noise than anything, dad says it's running about right from memory muffler was rusted to pieces same as the water tank, the governor is actually fully closed I tried to test it by closing it to see if it responded and couldn't go any further, I need to find a load for it
Old 08-27-2009, 08:33 PM
Images: 1
You might want to check the butterfly on the governor for leaks. You should be able to stop the engine by fully closing the governor.
Old 08-28-2009, 02:39 AM
steeleye steeleye is offline
Thats great. Bit on the noisy side in the shed with no muffler,but that couldn't be helped. To hear it run for the first time is a great feeling isn't it. Bet you couldn't wipe the smile off the dial for quite a while....well done.....Phil
Old 08-28-2009, 04:13 AM
Images: 1
There are few things more fun than when you first get an engine running
Old 08-28-2009, 07:35 AM
E27N's Avatar
No......no i couldn't. Cheers for the compliments guys.
got the fuel tank nearly done just have to seal a leak and make a bracket to mount it. Then I can start on the cooling tank. More pics as get it done.
Old 08-28-2009, 08:13 AM
Allan Dhu Allan Dhu is offline
Hi E27N,
Well done to get an engine up a running, love the sound
Cheers, Allan
Old 08-30-2009, 12:43 AM
E27N's Avatar
Got the tank finished although i stuffed up the outlet it's a bit on the piss and gave her a tub, I dunno whether i should paint it tho??????
Name:	30082009058 (Medium).jpg
ID:	61894   Click image for larger version
Name:	30082009059 (Medium).jpg
ID:	61895   Click image for larger version
Name:	30082009060 (Medium).jpg
Old 08-30-2009, 07:56 AM
WilliamInOz WilliamInOz is offline
if its a bit pissed it just added character to it.
The Following User Says Thank You to WilliamInOz:
Old 08-30-2009, 09:35 AM
E27N's Avatar
I'll buy that!!!!
Old 08-31-2009, 12:50 AM
Images: 1
It looks like it has a lot of original paint so I would be tempted to leave it as is; but I have seen a few of these beautifully painted and finished and they can be real eye catchers.
Old 08-31-2009, 07:15 AM
E27N's Avatar
yeah i think i might leave it as is, im trying to find something to run off of it, i know of an old 32v generator if i can pry out of the owners hands..........
Old 09-04-2009, 09:22 AM
E27N's Avatar
Got a mufflerer builted for it. Just needs painting with some pot belly black when I get some to finish and straiten the pipe on the engine my attempts to remove it have bent it..
i'm gettin' there........slowly
Name:	04092009071 (Medium).jpg
ID:	62203   Click image for larger version
Name:	04092009069 (Medium).jpg
Old 09-04-2009, 08:28 PM
The most fun you can have with your clothes on!!!!!!..........Phil
Old 09-05-2009, 05:20 AM
E27N's Avatar
damn right!!!
Sunbeam generator sparkplug54 Antique Gas Engine Discussion 11 01-08-2006 09:02 PM
Sunbeam Farm Lite Will Simmons Generators & Motors General Discussion 1 09-20-2004 02:32 PM
Sunbeam Farm-Lite Will Simmons Generators & Motors General Discussion 2 05-21-2004 12:13 AM
Sunbeam Byron Boike Generators & Motors General Discussion 2 06-04-2001 01:04 PM
