Smokstak Down Under
Southern Cross PAA engine age ?
I just bumped into a friend up at the Dowerin field day and he asked me if I knew anything about...
this thread has 10 replies and has been viewed 256 times
Old 08-28-2009, 12:16 AM
Inter Bloke Inter Bloke is offline
Default Southern Cross PAA engine age ?
I just bumped into a friend up at the Dowerin field day and he asked me if I knew anything about the years of manufacture of a Southern Cross model PAA engine which I am afraid I didn't, so I said I would ask here.
He is chasing the years of manufacture for the series and also the "year" for his engine which is a 4 HP with the number PAA 6717.
Anyone know ?
Thanks blokes,
Graham
Old 08-28-2009, 05:46 AM
Rusty Engines Rusty Engines is offline
Default Re: Southern Cross PAA engine age ?
Hi Graham
PAA 6717
Batch 6679-6734
Year 1939
Going out now be back latter with more info
Look here
Southern Cross Register
http://southern-cross-register.sumpy.com
The Following User Says Thank You to Rusty Engines:
Old 08-28-2009, 09:06 AM
Hi Graham
Southern Cross made what is referred to these days as a large 'P' and a small 'P'
The small 'Ps' as below
2hp PA (Fig 2074) 527 made from 1929-1935
3hp PA-A (Fig 2074) 306 made from 1931-1936
2hp PA-A (fig 2280) 350 made from 1936-1938
3hp PA-A (fig 2280) 559 made from 1936-1939
4hp PF (fig 2280) 60 made from 1937-1938
4hp PA-A (fig 2280) 1411 made 1939-1944
The differant fig numbers are for differant castings
Southern Cross made a lot of engines but in small numbers as above and any SC engine is worth while picking up
Ian
Old 08-28-2009, 09:07 AM
Thanks Ian, I think 1939 will keep Colin happy.
What is a PAA anyway ? I will do a bit of googling shortly to try and find out but its not one I have come across, are they very plentiful ?
Graham
Old 08-28-2009, 09:11 AM
Thanks again Ian, while I was replying to you another post turned up. I will still do some more checking but Colin should be happy now,
Graham
Old 08-28-2009, 09:19 AM
Hi Graham
There was only 1141 PA-A of Colin's type made and so far there is only 26 on the register these might be the only ones that have survived
Colin's now make 27 survived
Ian
Old 08-28-2009, 09:28 AM
Hi Graham
Some more info on a PAA
Old 08-28-2009, 09:37 AM
Thanks Ian,
I will print this off and send it to him, Colin isn't into computers but he will get a thrill from seeing what you have posted and it will give him some information, I gather he didn't know very much about it at all.
Graham
Old 08-28-2009, 06:09 PM
Mtype Mtype is offline
hi guys i have got 3 sourthern cross engines. A p 1307 6hp and 600rpm. I also have 2 engines that look the same as the one in the add but have a hopper on top of the engine and have wico ek mags. One i made into a mailbox for mum as the hopper was smashed and i didnt have all the bits to fix it. It has p 600rpm 2hp and engine number 1105 on the plate. I will get the details off the other one when i'm up the farm later. cam
Old 08-29-2009, 04:49 AM
Hi Mtype
PA 1105 (small P)
Batch 1096-1295
Year 1930
That engine is out of the first batch of PAs made and out of the 527 made there is only 8 including yours on the register
The ones with the water hopper on top are rare
PC 1307 (large P)
Batch 1296-1345
Year 1931
On the large Ps you often find the second letter not stamped
Large 'P' type engines
PB 3hp 250 made from 1927-1930
PB 3 1/2hp 9 made from 1932-1933
PB 4hp 373 made from 1931-1937
PC 5hp 275 made from 1926-1930
PC 6hp 432 made from 1931-1940
PD 7hp twin 10 made from 1920-1930
PD 8hp twin 16 made from 1932-1936
PD 9hp twin 12 made in 1932
PE 12hp twin 37 made from 1929-1936
As I have said before Southern Cross made a lot of engines but in small numbers as above and any SC engine is worth while picking up
Ian
Old 08-29-2009, 05:06 AM
hi ian thanks for the info i didnt have a chance to get up the farm today. i should tomorrow i'm realy glad i kept the engines now as thay wore sold but at the last minute the guy pulled out of the deal. thanks again cam
Steaming Under the Southern Cross Hoarder1 Stationary Steam & Traction Engines 5 12-08-2008 03:07 PM
southern engine and boiler works Edgar Antique Gas Engine Discussion 0 11-22-2006 09:56 AM
Southern Cross engines Rob Laurent Antique Engine Archives 1 03-24-2002 07:02 PM
Southern Cross Diesel Bronwyn Boyton Antique Engine Archives 1 01-24-2002 07:02 AM
Engine Show in southern NJ??? Bill Tremel Antique Engine Archives 4 09-22-2000 09:07 PM
