Welding Shop
Gear driven governor on Continental engine
Trying to locate a governor on a Miller Big 40G 3cyl gas welder. Its a HOOF governor and the model...
this thread has 9 replies and has been viewed 301 times
Old 08-31-2009, 01:18 PM
TDSB GUY TDSB GUY is offline
Default Gear driven governor on Continental engine
Its a HOOF governor and the model number on the governor is:GD915E 95016/TM20S00406.
Old 08-31-2009, 01:29 PM
BGunn BGunn is offline
Default Re: Gear driven governor on Continetal engine
Is it like this ? If not post a picture maybe one of us has a similar one.
https://www.surpluscenter.com/item.a...atname=engines
Old 09-01-2009, 08:16 AM
This is a pick of the governor post explosion, I regret I have none pre!!!
Old 09-01-2009, 09:16 AM
Do you have an engine model and serial ?
Old 09-01-2009, 09:23 AM
Miller Big 40g
Serial KF840326
Engine is a TM20
Spec b4644
Ser 95012209
Governor Mod GD915e 95016/TM20s00406 (HOOF)
Old 09-01-2009, 09:25 AM
Sorry the spec does not have a b its just 4644
Old 09-01-2009, 09:41 AM
Try these people,
http://www.foleyengines.com/EnginePr...ign=3396473708
they have helped me a few times. Make sure to tell them it is in a welder.
The Following User Says Thank You to BGunn:
Old 09-02-2009, 01:13 PM
mandmsurplus.com also has Hoof governors on their parts/support list. Good luck.
Old 10-15-2009, 09:24 AM
Just to put it out there, I found a number that superceded the original number on the old governor.
Old number was: TM20S00406 New number is:TM27S05161
That was of a BIG40G Miller welder.
I found it at MARINDUSTRIAL ( www.marind.ca )http://www.marind.ca/contact_us/contact_us.html
Thanks for the input from all.
Old 10-16-2009, 12:24 AM
Dempster Dempster is offline
Glad you found it. Just going to add a link for anyone else looking. Those were Pierce Hoof governors the company is now called Pierce Lockcraft.
http://www.thepiercecompany.com/spee...-governors.php
Can find manuals for engine at Wisconsin Motors site.
http://www.wisconsinmotors.com/partcatalog-ex.html
Belt Driven 10KW Governor Assembly davebrigg Military MEP and Aircraft Gen-Sets 1 10-17-2009 04:19 PM
Governors - gear driven or flywheel mounted Elwood Antique Gas Engine Discussion 1 01-26-2009 12:18 AM
Onan Continental motor Pierce governor DAVE PRESTIDGE Onan Generators 4 04-26-2007 11:43 PM
MDJA Gear Driven Impeller Pump WTB BTPost Onan Generators 9 11-04-2005 04:33 AM
willys gear driven waterpump cjs10 Generators & Motors General Discussion 0 10-01-2004 11:30 PM
