Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Reel Mower Blades
I picked up my first reel mower, Its a rocket eclipse. I was wondering if anyone knows a good way...
this thread has 3 replies and has been viewed 650 times
Old 09-01-2009, 07:39 PM
trashman6062 trashman6062 is offline
Default Reel Mower Blades
I picked up my first reel mower, Its a rocket eclipse. I was wondering if anyone knows a good way to sharpen the blades.
Any thoughts? Thanks in Advance.
Chuck
Old 09-01-2009, 09:09 PM
Arlie Levy Arlie Levy is offline
Default Re: Reel Mower Blades
Try and hook up with golf course maintainance. They usually have ways to sharpen them. The greens mowers are reel mowers.
The Following User Says Thank You to Arlie Levy:
Old 09-02-2009, 07:52 AM
eric67m eric67m is offline
Real quick as I should be leaving for work...
Backlapping or full grinding
Backlapping is done by turning the reel backwards (with a handle or seperate motor) and applying lapping compound until each blade and the bed knife are free from knicks. Adjust reel clearance to either just cut paper (some people do it differently).
Grinding is done by using a special tools to grind the bed knife and a special tool to grind all of the blades on the reel. General done at a relief angle so only a small part of each blade touches. This is followed up by backlapping to insure that every part of every blade has the same gap and seat.
Eric
The Following User Says Thank You to eric67m:
Old 09-02-2009, 08:08 AM
grub54891's Avatar
I have a sharpener for reel mower's.Never used it but it's got a file peice in it attached to a handle.I intend to try it but the reel mower I have is in storage along with the tool.I'll try to get it and a pic when I'm out there next.
The Following User Says Thank You to grub54891:
Reel Mower - what is it? j dayman Garden Tractors / Mowers / Scooters 10 02-15-2012 07:18 PM
Jacobson Reel Mower.. FarmallIH Garden Tractors / Mowers / Scooters 7 06-24-2007 09:29 PM
handles for reel mower Sky Antique Gas Engine Discussion 0 08-06-2006 10:58 AM
reel mower Brian_369 Garden Tractors / Mowers / Scooters 1 04-24-2006 08:16 PM
what do you think is the rarest reel mower? Austen Garden Tractors / Mowers / Scooters 2 10-17-2005 09:07 PM
