Welding Shop
Silver Solder
I have two tubes I want to join, the columns on a boring bar. I plan to machine a 2" male taper on...
this thread has 1 replies and has been viewed 328 times
Old 09-05-2009, 07:40 PM
J.B. Castagnos J.B. Castagnos is online now
Default Silver Solder
I have two tubes I want to join, the columns on a boring bar. I plan to machine a 2" male taper on one, and a female taper in the other to match, leaving about a .040" ridge for it to square up. Onthe outside taper I will machine a recess of about .004", leaving a 1/4" section on each end to line it up. In the recess I wll use some silver solder ribbon .005" thick. I'll coat the shafts with flux and put them in the press to force them togehter as the solder melts. Any advice on which solder to use? McMaster list several different types and I'm not sure which to use. The material is steel.
Old 09-05-2009, 09:14 PM
Default Re: Silver Solder
I'd try to use Some Stay Silv Flux, It looks like flour mixed with water. No 45 round silver solder in the diameter you like to work with. We've use it for years at work to silver solder a sawed off odd hydraulic end to a good end to put on the end of a hydraulic hose when we didn't have that thread fitting. Provided it's done correctly, we've never had a problem.
The Following User Says Thank You to Pat Barrett:
Reliable Solder stove smtwins Blacksmithing and Metallurgy 3 11-15-2008 11:37 PM
Heat gun and solder Leonard Keifer Machine Shop and Tool Talk 5 01-04-2008 11:25 AM
Silver Lining Hal Davis Antique Engine Archives 0 01-28-2003 08:49 PM
Cast Iron Solder Jason Weinke Antique Engine Archives 6 09-24-2001 07:26 PM
silver solder geartooth? Wayne Zuccarello Antique Engine Archives 3 12-25-2000 11:54 PM
