Welding Shop
Miller Bluestar 180
I Have a Miller Bluestar 180,would anyone know how to seperate the engine (12.5 Kolher) from the...
this thread has 3 replies and has been viewed 207 times
Old 09-13-2009, 10:31 PM
Richard Gibson Richard Gibson is offline
Default Miller Bluestar 180
(12.5 Kolher) from the armature. I can't tell if it is pressed on or if it is threaded. thanks Richard
Old 09-14-2009, 09:21 AM
K D Redd K D Redd is offline
Default Re: Miller Bluestar 180
Most generator rotor are fitted to a tapered shaft. What I do is remove the center bolt, Tap the hole with to install a grease Zerk. Then use a grease gun to pressurize the cavity where the thru bolt was. The make a mini-hydraulic cylinder. Some time the rotor will pop right off. Sometime it will take a day or so of setting. One I worked on did not come off until I bumped the rotor with a hammer. When I did the rotor JUMPED off.
Kent
Old 09-14-2009, 02:05 PM
Kent thanks for the advice,but this armature does not have a through bolt and is solid.Any ideas
Richard
Old 09-18-2009, 08:03 PM
if anyone is interested this was a threaded shaft,right hand threads
Miller AEAD ~Wittes-End~ Onan Generators 2 08-31-2009 05:35 AM
Miller Dialarc 250 AC/DC Randy Hart Welding Shop 3 06-12-2009 01:03 PM
Miller Generweld 130 swampy Welding Shop 4 08-23-2008 11:35 AM
Miller 351 jnorton Welding Shop 3 06-29-2007 11:40 PM
Miller-Knoblock Rick Young Generators & Motors General Discussion 1 02-06-2003 08:56 AM
