Case C value?
found a 1933 case C tractor, full steel, lugs good skid rings good, tin is perfect. old...
this thread has 20 replies and has been viewed 779 times
Old 09-22-2009, 12:08 AM
ssimntih's Avatar
ssimntih ssimntih is offline
Images: 50
Default Case C value?
found a 1933 case C tractor, full steel, lugs good skid rings good, tin is perfect. old restoration, tractor is stuck from sitting in a shed for years, totally complete, manifold is burnt out. anyone got a clue what its worth?
Old 09-23-2009, 09:13 PM
ssimntih's Avatar
Images: 50
Default Re: case C value?
anyone...?
Old 09-24-2009, 12:38 AM
As long as folks are knocking each other to the ground getting in here.......
I wouldn't offer over a thousand for that tractor.
It's been sitting for years is the main reason.
You don't know about the radiator.......and the gas tank, carburetor and magneto are givens.......
Old 09-24-2009, 01:44 AM
Dave Olson Dave Olson is offline
I bought a 'barn fresh' running C on full steel two years ago (?, maybe 3) for $750. All the tin is in pretty decent condition.
Old 09-24-2009, 04:43 PM
I need to move closer to Dave so his good luck can rub off!
Old 09-24-2009, 07:28 PM
$750 sounds good for a running one.
O Great Moderator is about right.....of course....
I am thinking $800 is the roof on the stuck one that ss found
Old 09-26-2009, 09:04 PM
ssimntih's Avatar
Images: 50
the only problem is there are none around here... those that were are owned by a family around here that has several, so id have to drive quite a distance for one, i think i can get it for $1250... i hate to massively overpay but its either that or have to drive a couple hundred miles for another.
Old 09-26-2009, 11:23 PM
Glenn Gieszler Glenn Gieszler is offline
Images: 101
Do what you have to do if you want it, for what its worth if it is a 1933 it is a low production year someone had to have had money to buy it during the depression, a $1,250 value would be ok if it still has a flat belt.
Old 09-27-2009, 12:59 PM
SS,
Call Don Livingston for a price on a manifold. 507-433-0073.
If you can get it loose, have a local shop do the valves, and put it back together yourself, then you will be just fine. If you want it, buy it. A couple thousand dollars is just pocket change nowdays, if you are happy with the purchace it will be worth it.
Tony
Old 09-27-2009, 01:14 PM
ssimntih's Avatar
Images: 50
thanks for your input all, i picked up a spare head for it out of a salvage yard so if its in good enough shape ill probably rebuild that one, the only thing that bugs me is why its stuck, sitting stuck i can handle but rained in the pipe stuck gets to be pretty involved
Old 09-30-2009, 10:15 PM
Justin,
Hook a piece of cloth on the end of a piece of wire and go after top of piston through the plug hole. If the fabric comes out dry this is good news. I am assuming you need to trailer this machine home. Before you load it put a 1/4 cup of diesel fuel in each cylinder. The trailer ride home over different types of road surfaces will send all different types of vibration up through the tractor. This "road vibration" is magnafied with steel wheels and as it shakes or buzzes through the tractor little air bubbles will rise up and float away from rings as the diesel creeps in around the rings. A tractor that is not stuck very bad can be loose when you get home!
If you place the tractor in high gear and leave the chains loose, starting and stoping will place a good bit of turning force against the stuck engine as the weight of tractor rocks back and forth on the trailer. This practice obviously should only be done on secluded back roads for everyones safety and law enforcement will not like loose chains on a load!
Just an idea,
Tony
Old 10-01-2009, 11:27 AM
ronm ronm is offline
I knew an old tractor guy who swore by the "loose chain & road gear" method of unsticking an engine...claimed he had broken loose several that way.
Old 10-01-2009, 03:30 PM
Default Re: Case C value?
It can work,
I got one loose on vibration & diesel alone, and I got three unstuck with the "loose chain & high gear" method over the years
Old 10-03-2009, 02:25 AM
The 25-50 Townsend that was purchased at the great "Oscar's Dreamland" sale was stuck when we looked it over.......it wouldn't BUDGE.
When it arrived in Wisconsin it was loose....... .......
Old 10-03-2009, 08:10 AM
midpw midpw is offline
A fellow drove about 300 miles to buy my little Allis B. We had thoroughly discussed the fact that it was stuck hard and that I had been soaking it routinely for about 3 months at the time. I sold it to him for a "stuck" price and we were both happy with the deal.
He called the next day and let me hear it running over the phone.........said that when he rolled it off the trailer, the engine was free and loose!!!
Yes, it works,
Bruce
Old 10-12-2009, 12:25 AM
ssimntih's Avatar
Images: 50
well sure give that a try, its a good 65 miles of crappy rough stop and go two lane roads between there and home. ill get some pics up when its on the home turf.
The Following User Says Thank You to ssimntih:
Old 10-13-2009, 01:15 AM
ssimntih's Avatar
Images: 50
it made the trip home, its sitting in the shop with some tension on the wheels to help free it up. if you rock it back and forth the fan moves so thats a start. still havent found a good manifold for a decent price, anyone seen any d-series case tractors donating their organs in the local scrap yard?
Old 10-13-2009, 11:24 PM
ssimntih's Avatar
Images: 50
well here she is fella's, in all her glory.
ID:	64808   Click image for larger version
ID:	64809   Click image for larger version
ID:	64810   Click image for larger version
The Following 2 Users Say Thank You to ssimntih:
Old 10-14-2009, 10:10 PM
Looks pretty good.
If you are not in a hurry, a D series manifold will turn up in time. All original old manifolds that are not being reproduced have been drying up and jumping in price in the last few years. you can expect to pay $200-$300 for a decent/usable C-hot manifold if you can even find one for sale
I think you did just fine on the tractor though, should be a fun project!
Old 10-16-2009, 01:02 AM
ssimntih's Avatar
Images: 50
well for the last few days weve been rocking and jamming around on this thing trying to get it broke loose, it was only stuck on the very last cylinder after the ride home. tonight i put a pipe wrench on the crank hub/pulley on the front of the engine and put a cheater pipe on that and jammed around on it. it never budged so i pulled the head off, ratched strapped the pipe on the pipewrench to the wheel to pull tension on the crank, and bopped the #4 piston with a rubber mallot, it rolled right over... rediculous, i honestly dont see how it was stuck so hard if thats all it took. oh well at least its loose now.
Case 50 lazman11 Stationary Steam & Traction Engines 58 09-17-2008 11:03 AM
What would you do if your Non Case engine had a Case smokebox door and ring put on it Casemaker Stationary Steam & Traction Engines 11 08-30-2007 04:47 PM
OLD Case Tanner Remillard Stationary Steam & Traction Engines 25 11-22-2006 10:10 PM
110 Case? Lippy Stationary Steam & Traction Engines 54 09-15-2006 03:24 PM
60 hp Case Mark Johnson Stationary Steam & Traction Engines 8 09-19-2003 04:24 PM
[IMG] code is Off
