Briggs ZZ coils
I hear they are unavailable...except by rewinding them by hand...has anyone done this?
this thread has 5 replies and has been viewed 348 times
Old 09-22-2009, 09:23 PM
Clark Bigger Clark Bigger is offline
Default Briggs ZZ coils
Old 09-22-2009, 09:43 PM
ehpower2 ehpower2 is offline
Default Re: briggs ZZ coils
send them to a magneto shop or call around that is how i would do it or find a good parts motor but keep the coil the not common as they used to be
Old 09-22-2009, 10:21 PM
hitnmiss hitnmiss is offline
Clark try Bill Lopoulos for the rewound coils. He's square and will help you as much as he can.
He's located in Mass. but he does make the Jacktown show. There're NOT cheap
BLOPOULOS@aol.com magnetoparts.com
Regards BILL
Old 09-23-2009, 09:34 AM
K D Redd K D Redd is offline
Default Re: Briggs ZZ coils
I have a PDF down loaded from this site, I think, that show how to modify the armature to install a magneto coil from a import Moped. Not sure how to post the PDF and I hesitate to do so because I did not originate the PDF.
Kent
Old 10-03-2009, 02:20 AM
Dempster Dempster is offline
Rewind unless find a used or NOS one. Also try Marks Magneto, Mainely Magneto or Bob's Small Engine Repair.
Old 10-03-2009, 08:32 PM
I just looked at the PDF of the coil convertion for the ZZ engine. It was posted BY Craig DeShong. He IS A MEMBER of SMOKSTAK. Contact him about the coil conversion HE developed for the OLDER BRIGGS LETTER SERIES engines. His E-Mail address should be in his profile.
Kent
The Following User Says Thank You to K D Redd:
Briggs F series coils Craig DeShong Small Air Cooled Gasoline Engines 5 04-19-2009 07:27 PM
Coils for Briggs engines John Schwiebert Magnetos, Ignition Coils and Spark Plugs 2 04-16-2009 02:11 AM
Test Briggs "Horse Shoe" Coils Jonathan Widelo Small Air Cooled Gasoline Engines 3 10-09-2008 03:41 PM
coils BDilgard Machine Shop and Tool Talk 6 09-01-2005 03:27 PM
coils Alex F Antique Gas Engine Discussion 0 08-08-2005 09:54 PM
