Welding Shop
Chemetron Sureweld Model DRCP-250T
Hi everyone, I'm new to this, so if anyone can help me out there, here is my problem.I have a...
this thread has 2 replies and has been viewed 189 times
Old 09-27-2009, 09:26 AM
capt will capt will is offline
Default Chemetron Sureweld Model DRCP-250T
Hi everyone, I'm new to this, so if anyone can help me out there, here is my problem.I have a Chemetron Sureweld machine that I use for mig welding. It's a 200 volt three phase unit. It worked fine for many years until last. An electrician friend of mine found that the finned rectifier was burned through and was causing the problem. Does anyone out there know of a unit like this or knows where I might obtain this part, thanks Will
Old 09-27-2009, 11:28 AM
K D Redd K D Redd is offline
Default Re: Chemetron Sureweld Model DRCP-250T
Are you talking a rectifier made from many flat plate that are usually square?
If so these are old selenium type rectifiers. I do not know if any are still made. You could build a rectifier assemble using stud mount rectifier. You can buy industrial rectifier diode with forward current of around 500 amps. I have never price one this large but I bet they are pricey. The Peak Reverse voltage of 600 volts is higher than needed for a welder. Depending on how your welders secondary is set up you will need at least four to build a bridge rectifier or you could need as many a 12. If you would need 12 you most likely would not need diodes with the very forward current.
Kent
Old 09-27-2009, 06:46 PM
Hi Kent, thanks for the info on my Chemetron mig welding power unit. I never gave it a thought about making a new one, that's a great idea. I'll ask my electrician to remove it and go from there. I'll let you know how it turns out, thanks again, Will
Sureweld model HGW-150P jeremy griffin Welding Shop 4 10-17-2009 03:26 AM
Mogul S/S Scale model and not a Pacific Model Design Paul Spence Scale Model Engineering 15 06-25-2009 09:13 AM
Briggs Model PB Crank (For Moto-Mower Detroit Model) Jonathan Widelo Small Air Cooled Gasoline Engines 0 02-05-2009 02:43 PM
Briggs engine model W series and Y model Travis Small Air Cooled Gasoline Engines 1 02-01-2009 08:58 PM
Sureweld Welder Help? ken stewart Welding Shop 3 10-21-2006 11:35 PM
