Antique farm cart axles and wheels – information needed about fitting.Hi. I’m a writer. In my present novel, set 150 years ago, I need to describe what’s involved in...this thread has 2 replies and has been viewed 307 times
Hi.
I’m a writer. In my present novel, set 150 years ago, I need to describe what’s involved in removing a wheel from the axle of a horse-drawn farm cart. To explain: I have a band of highway robbers intent on holding up a coach. As a subterfuge, they plan to block the road with a disabled farm cart, and to achieve this I thought of using a wheel coming off, seemingly by accident. What is going to really happen is that the robbers will have to manhandle the wheel off. So I guess I need to know how the wheel would have been fixed to the axle, in order that I know how to get it off. Thanks for any help you can provide. |
The coach would have to be jacked up then a nut,washer and pin would have to be removed.If the robbers wanted to sabotoge the coach they would simply remove the the axel pin and the nut would work it's way off.Hope this helps .Regards, Jeff
Sounds good, Jeff. I should be able to work with that. Thanks.
| Rumely thresher wheels and axles needed | Brad Hauck | Farm + Industrial Antiques and Collectibles | 1 | 10-06-2009 11:26 PM |
| Wheels of Yesteryear Antique Power Show | Caseboy | Antique Gas Engine Discussion | 0 | 07-19-2009 11:19 PM |
| SW Va Antique Farm Days - 6/19-21 | Machineryman | Antique Gas Engine Discussion | 5 | 06-18-2009 11:26 AM |
| Steel Wheels at the Peterson Farm | Randy L Peterson | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 2 | 10-15-2008 04:26 PM |
| Hit and miss cart axles | Tom Kilgore | Antique Gas Engine Discussion | 3 | 02-22-2008 10:25 AM |
