Battery & coil ignition sparks continuouslyHere's a newbie question. I have a F&J farm pump engine with battery & coil ignition. I hooked up...this thread has 3 replies and has been viewed 293 times
Here's a newbie question. I have a F&J farm pump engine with battery & coil ignition. I hooked up the battery & coil. The prior owner had put together a battery & coil box with an on/off switch. When I flip the switch on, the spark plug sparks continuously, without even rotating the flywheel. Cranking the flywheel has no effect - the spark just keeps going. Any suggestions?
im guessin you have a modle t buzz coil on there and the ignition mechinzim isnt set up right. it should only spark when it needs to.
It should only spark when the timer lets it. Search buzz coil set up on stak and it should get you going. good luck Bryon |
Wiring a buzz coil: -negative post of battery wired to engine ground. Wire from timer contactor to - on coil + post on batterywired to one side of a switch, + from switch to + on coil. Hi tension to spark plug. As the timer wipes the contactor, the grounding circut is completed, causing the coil to spark. If you still have spark all the time, check to make sure timer is isolated from engine ground until the contact is made.
| Battery and coil ignition. | KyleBlankenship | Antique Gas Engine Discussion | 6 | 09-11-2008 11:13 PM |
| Battery and coil ignition to run a Maytag 82 | Tom S | Maytag Engine Collectibles | 9 | 11-22-2007 05:57 AM |
| coil and battery ignition help | OldAgIron | Antique Gas Engine Discussion | 13 | 11-27-2006 06:40 PM |
| Battery & coil ignition, How? | Tanner Remillard | Antique Engine Archives | 16 | 07-27-2002 10:47 PM |
| Battery and coil ignition | Mark | Antique Engine Archives | 13 | 06-04-2002 11:30 PM |
