Blade on a Farmall "A" for snow?
I'm looking to aquire an "A" and want to mount a front snow blade on it . Any Ideas , I do have a...
this thread has 9 replies and has been viewed 313 times
Old 10-05-2009, 10:31 AM
Bud Tyler Bud Tyler is offline
Question Blade on a Farmall "A" for snow?
I'm looking to aquire an "A" and want to mount a front snow blade on it . Any Ideas , I do have a snow blade for a bush-hog D4-10 that I can possibly mount without too much trouble ,but I'm just looking for ideas . For lifting or possibly mounting on the back instead of the front . I may even have a small cylinder to pick it with or I might mount a 12V winch for a quick user situation .
Old 10-05-2009, 10:22 PM
Default Re: Blade on a Farmall "A" for snow?
If you DON'T mount the blade on the front you'll regret it forever.
Plowing in reverse gets old REAL fast.......
Old 10-06-2009, 07:06 AM
That is actually what I was thinking ,but being old fashioned "curmudgens" as most of us are ,everyone has an idea of how things should be done. Looked at the tractor and the owner said the tire looked a little low ,he tried to put air to it and got a calcium shower so I can get the tractor for $600 or add $180 with a new tire ? So I'm looking for a couple pull offs
Old 10-06-2009, 08:51 AM
EdDarowski EdDarowski is offline
The "A" doesn't come with hydraulics. If it doesn't have an aftermarket hydraulic system, you'll need to add one, or use the "Armstrong" method. Ed
Old 10-06-2009, 10:30 AM
actually considering a cheap winch similar to a four wheeler concept.I understand at one point they used exhaust help with springs also?
Old 10-06-2009, 11:58 AM
There was an exhaust lift. I know nothing about them, except that few have survived, and no parts are available. Ed
Old 10-06-2009, 03:35 PM
The exhaust lift is a cumbersome thing.
You should be able to mount a small hydraulic pump at the front of the engine and drive it with a V belt. It takes very little to lift just a blade.
I did that on the other JD L I had at one time......it worked great!
You might want to consider looking for wheel weights and get rid of the fluid in the tires......but the damagae has probably already been done....
Old 10-07-2009, 01:23 PM
Believe it or not it comes with front and rear factory weights plus the rears are or were loaded My boss who I'm buying it from thought they looked a little low and put the air to the left rear and got an earache and calcium shower:I just wish I'd gotten it home first.
Old 10-07-2009, 02:00 PM
Travis's Avatar
Travis Travis is offline
click my name to see my 1945 A with spring lift
any type of lift system is rare for the A especially the exhaust lift
hope helps
Old 10-07-2009, 07:14 PM
Nice ! It was alittle hard to see in the picture but I got the idea ,not sure how to incorporate it in the front . Because like Craig said I'd probably be hating it plowing backwards
1939 Farmall "A" Need help!! TStrooski Antique Tractor Talk 1 08-21-2009 02:51 AM
IH Cub NOS snow blade Randy Hart Garden Tractors / Mowers / Scooters 8 08-07-2009 07:42 PM
Farmall "B" and "M" HBurk Antique Tractor Talk 2 04-25-2009 11:01 PM
Jacobsen snow jet 20" AndrewOneal Small Air Cooled Gasoline Engines 1 06-23-2008 12:48 AM
Union Pacific RailFest 2007- "844" & "3977" Robert M Stationary Steam & Traction Engines 18 10-29-2007 10:05 PM
[IMG] code is Off
