Tap Spark Ignition
* This is a 1904 Marine engine ad, it mentions jump or tap spark, is anyone familiar with the term...
this thread has 2 replies and has been viewed 242 times
Old 10-05-2009, 11:17 PM
Richard Durgee Richard Durgee is offline
Default Tap Spark Ignition
This is a 1904 Marine engine ad, it mentions jump or tap spark, is anyone familiar with the term "Tap Spark" ?
Name:	Keystone 1904 1.jpg
Old 10-05-2009, 11:42 PM
Exclamation Re: Tap Spark Ignition
Both terms, jump spark and tap spark, are archaic terms for ignition systems. Jump spark refers to spark plug ignition. The spark has to 'jump' a gap in the plug, thence the name. Tap spark refers to ignitor ignition. Usually, on the marine engines, the ignitor is tapped by the trip mechanism, and it was usually battery and coil for power. Marine engines, like aircraft engines and fire equipment, often had 2 seperate ignition systems, that operated independantly from each other. At the time, magnetos were often not that reliable, or powerful enough to start the engine in cold or damp weather. A battery and coil was often used to start the engine, and then it was switched to magneto for running. If the mag quit, the battery and coil would get you home.
The Following User Says Thank You to Andrew Mackey:
Old 10-06-2009, 12:37 AM
Default Re: Tap Spark Ignition
Thanks Andrew,
I thought that "Tap Spark" was probably a local, casual or nonformal reference to mechanical or make and break ignition but I have never heard it used or seen it in print anywhere other than the ad in above post ?
BGD Ignition no spark riptmetal Onan Generators 10 09-18-2009 09:05 PM
First use of spark plug ignition in stationary engines? oldironcollector Antique Gas Engine Discussion 6 01-02-2009 12:14 PM
Field Brundage SS spark plug ignition Jimmy OHagan Antique Gas Engine Discussion 3 08-16-2008 01:36 PM
KW Ignition Co. DaveE Magnetos, Ignition Coils and Spark Plugs 2 01-18-2008 08:12 PM
JD "E" 1-1/2 open crank spark plug model with Coors Light Ignition Mark Congden Antique Gas Engine Discussion 6 10-17-2005 12:42 AM
