Restore threads for spark plugs on old Mack truckRestoring 1918 chain drive model AC 5-1/2 ton Mack Truck. The spark plugs holes in the cast iron...this thread has 7 replies and has been viewed 433 times
spark plugs holes in the cast iron heads are damaged and need to be chased. A new 7/8" 18 tpi tap cost is about $ 180.00 with a long delivery. As it will be used only once I prefer not to buy a new one. The original plugs that Mack installed were Splitsdorf/Edison. The plugs in the truck when I got it were Champion W-18. I think that Champion Stock No. 429 part number 3X will work. I hope to be able to either rent or buy a used tap and am seeking information on restoring these threads. Comments and ideas will be appreciated. Charley M. |
I have seen a couple of sparkplug thread chasing tap sets go on ebay. They are double-ended taps, one side is 18 mm, the other 7/8-18. They're typically part of a set that also has a 10mm/14mm tap.
EDIT: I checked McMaster-Carr. www.mcmaster.com Part number 2595A425 (Same as 2595A828) Special Thread High-Speed Steel Hand Tap 7/8"-18, H3 Pitch Diameter, 4 Flute, Bottoming In stock at $58.84 Each And their delivery is lightning-quick. |
Check at the local Napa store. Jawco makes a double ended thread chaser for spark plugs, has a hex in the middle. Run about $20.00. If you don't find one, PM me and I've also got a tap you can use.
The Following User Says Thank You to Pat Barrett:
Hello
Travers Tool Co. 1-800-722-0703 Part # 14-056-183 7/8-18 Tap $28.07 each I'd say who ever told you $180.00 was making a wee bit of profit. Good Luck LeRoy
The Following 3 Users Say Thank You to LeRoy IHC:
We have shaired all of the tap secrets with you now whair the pictures of the truck thanks dave wachter
The Following User Says Thank You to DaveWachter:
Eric - Thanks for heads up on Mc-Carr. My copy is #94 and doesn't have the numbers you called out in your reply. I will call them tomorrow.
Charley M. |
Dave - I will post some pictures of my A/C Mack very soon. Charley M
Good luck with the restoration - I am doing a 1929 AC - pictures at www.rustytrucks.com. I would love to keep in touch and exchange experiences and tips - two heads are better than one!
I would be particularly interested in any leads you get for parts, particularly pistons, valves springs and so on as well as a water pump and a magneto. But in the meantime, all the best, Paul |
| 1959 Mack truck | ernie magnelli | Trucks, Trailers and Hauling for Shows | 0 | 08-19-2009 10:11 PM |
| 1929 Mack AC Truck Help Wanted | paulbrook | Antique Autos and Trucks | 8 | 08-10-2009 06:24 AM |
| 1918-1930 Antique Mack Truck Wheel Set rare metal spoke cushion tires | Lilbethy | Antique Autos and Trucks | 1 | 04-09-2009 12:56 PM |
| 1959 Mack Truck | Tom Sampson | Antique Autos and Trucks | 21 | 12-06-2007 07:48 PM |
| Threads per inch and size of Spark Plugs | Pat Barrett | Antique Engine Archives | 10 | 10-26-2004 02:15 PM |
