Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
Wisconsin THD Governor
I am in need of a replacement governor assembly part number T96LS1 for my Wisconsin THD engine. ...
this thread has 5 replies and has been viewed 140 times
Old 10-06-2009, 07:24 PM
Doun Doun is offline
Default Wisconsin THD Governor
I am in need of a replacement governor assembly part number T96LS1 for my Wisconsin THD engine. Last time it ran, a governor flyweight fractured and went through the governor housing...ugly scene...
Any help locating this component would be greatly appreciated.
Old 10-06-2009, 08:21 PM
21avery 21avery is offline
Default Re: Wisconsin THD Governor
check ebay not one now, but always THD parts there .
The Following User Says Thank You to 21avery:
Old 10-06-2009, 08:31 PM
Did you ever ear of fractured flyweight? I will need to open the gearbox as I did not recover all pieces...
Old 10-06-2009, 09:58 PM
Rodrigue Caron Rodrigue Caron is offline
HI,Doun
P erhaps i have someting , send me an email for more informations. In french if possible.Rodrigue.
Old 10-06-2009, 10:22 PM
Merci Rod,
Mon gouverneur est sorti du housing juste apres le start. Je crois qu une flyweight a lache... Je crois que le reste du moteur est OK mais je dois le confirmer en ouvrant l gearbox...je n ai pas trouve toutes les pieces du gouvereur.
Moteur Wisconsin
Model THD
S/N 3135476
Spe 148404
Merci,
Doun
Old 10-07-2009, 11:04 PM
Bill Geyer's Avatar
Images: 11
My governor did the same thing when the plastic gear on the camshaft shelled it's teeth The parts cost over $300 from the local Wisconsin dealer. The new gear is cast iron.
May the Stak be with you
Bill
Wisconsin THD governor "hunts" after 20-30 mins metalmagpie Antique Gas Engine Discussion 6 08-18-2009 11:22 PM
Governor help pnora Welding Shop 2 04-11-2009 07:55 PM
Wisconsin AEH governor info Bill Sherlock Small Air Cooled Gasoline Engines 6 04-03-2007 07:59 PM
Help with ID...Governor?? Larry W Messer Antique Gas Engine Discussion 4 07-03-2006 06:54 PM
Oil Governor/Steam Governor Ed Bertschy Stationary Steam & Traction Engines 2 02-28-2003 10:35 AM
