Bulldog Ignitor Points have weak spark
I rebuilt the ignitor on my 2.5 HP Bulldog and made new points out of 1/4" solid copper rod. Spark...
this thread has 5 replies and has been viewed 269 times
Old 10-07-2009, 09:25 PM
H.P. Firmin III H.P. Firmin III is offline
Default Bulldog Ignitor Points have weak spark
I rebuilt the ignitor on my 2.5 HP Bulldog and made new points out of 1/4" solid copper rod. Spark is very weak, blue but thin, like static electricity. Battery is hot, have great ground,points line up perfectly and are touching flat against each other. Whats my problem? Are the points too heavy? Wrong Material? Thanks for your help in advance!
Old 10-07-2009, 09:37 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Images: 1
Default Re: Bulldog Ignitor Points have weak spark
I don't think copper make good point material I have used nails before and they work good for me.
The Following User Says Thank You to Steve Kreiner:
Old 10-07-2009, 11:33 PM
Just a common steel framing nail? Is there an alloy that works better? Thanks!
Old 10-08-2009, 01:36 AM
Eric M.'s Avatar
Eric M. Eric M. is offline
Steel works fine and throws a nice fat spark. Stainless steel works fine too. You COULD use platinum, but you will not see enough improvement to warrant the cost. Many factory ignitors were cast iron on cast iron.
The Following User Says Thank You to Eric M.:
Old 10-23-2009, 08:47 AM
cobbadog cobbadog is offline
I knew a bloke who used to use our countries 5 cent coin (high content of silver). He silver soldered them in place then draw filed them smooth and then used an oil stone to polish them. He used this type of contacts on electric forklifts which worked on 48 volts. Now I do know here in Oz it is illegal to deface the coins but he just didnt care about that because to buy the real contacts were over $100.00 per set.
P.S. His contacts outlasted the genuine ones by up to 3 times.
Old 10-23-2009, 01:49 PM
Gary Pflum Gary Pflum is offline
Just a dumb question. Are you using a coil on your engine or a correct coil? I do know if you take a battery, coil, and copper wire and hook them up in a series and touch the wire ends together they will spark as good as the points will within reason. On the same note if you touch the copper wires together several times the copper will start to show electrical damage. Wrap the copper wire ends around two nails and touch them several times. The steel nails will show less damage.
Weak Spark mrmechanic1965bc Military MEP and Aircraft Gen-Sets 1 06-08-2009 08:26 AM
Weak spark for sure Elwood Antique Gas Engine Discussion 1 05-18-2009 12:18 AM
Weak Ignitor Spark, IHC M W. Bittle Antique Gas Engine Discussion 2 05-09-2005 12:30 AM
LB Mag weak spark Bill Schaller Antique Engine Archives 7 08-12-2004 08:33 PM
Weak spark - Help Nathan Antique Engine Archives 2 03-09-2000 02:32 PM
