Onan 16 hp on lincwelder 225Getting way to much oil up in the breather tube to carb cloggs filter any help would be great ...this thread has 8 replies and has been viewed 334 times
Getting way to much oil up in the breather tube to carb cloggs filter any help would be great Dave
Sounds like worn pistons and rings ? Too much back pressure in crankcase and not enough compression from being worn out.
The Following User Says Thank You to Dempster:
Thanks i did a compession test today 120 both cylinders but tommorrow im gonna pull dip stick ans see if there is presure yhink i need a rebuild job
Dave,
Ask over in the Onan generator forum or do a search there - there are millions of Onan generators around and the resident smart guys there may have some suggestions. I saw a reference to this on a genset recently but can't remember what they said now. ![]() Ray |
The Following User Says Thank You to Ray Griffiths:
Hi Dave
I purchased one of these welders several years ago from a company that said it needed a engine rebuild (it was blowing oil out of the crankcase breather) , when I got it back to my shop I checked it over and found the oil way over the full mark , I drained the oil and refilled the crankcase with new oil to the proper level and started it , it ran perfectly , didn't use any oil and ran and welded fine. The problem was that someone over filled the oil ! With 120lbs of compression I would not suspect that it needs a rebuild , clean oil and the proper level when hot. Good luck with it. Tom |
The Following User Says Thank You to The Engine Shed:
I have no experience on that Onan, but there is probably a one way breather valve some where to maintain a vacuum in the crank case. It could be broken, or inoperative.
May the Stak be with you ![]() Bill |
The Following User Says Thank You to Bill Geyer:
Might have chunks of carbon come off inside engine too just gunking it up if been sitting a long time. Onan recommended to pull the heads and clean them every 200 hours.
clean breather check valve fill to correct oil level and weld to your harts content
The Following User Says Thank You to doug hodgson:
If you find oil overfilled MAKE SURE it is not contaminated with gas. Sometimes a carb problem will let gas enter the crankcase.
The Following User Says Thank You to Stimw:
| Lincwelder 225/ Onan problems starting | distinguished1 | Welding Shop | 8 | 10-20-2009 10:04 AM |
| Batterys for Lincwelder 225 with Onan | Dave Jensen | Welding Shop | 4 | 02-18-2009 07:27 PM |
| Lincwelder 225 Onan CCK spark problem | distinguished1 | Onan Generators | 4 | 09-11-2008 11:34 PM |
| Parts manual for Lincwelder 225/3-AS Onan engine | HankA | Welding Shop | 4 | 07-12-2006 09:43 PM |
| lincwelder 225 | NayenezGene | Welding Shop | 4 | 12-11-2005 01:37 PM |
