IHC LB Mag
Close inspection of a mag on an LB I'm trying to get running revealed a hairline crack in one of...
this thread has 4 replies and has been viewed 250 times
Old 10-09-2009, 08:15 AM
NoSpark NoSpark is offline
Default IHC LB Mag
Close inspection of a mag on an LB I'm trying to get running revealed a hairline crack in one of the magnets length wise. I'm assuming this is nothing to ignore. Is it common?
Thanks Brownie
Old 10-09-2009, 04:42 PM
ehpower2 ehpower2 is offline
Default Re: IHC LB Mag
well is the magnet loose or can it be moved by the armature if not and its secured i would personaly think that its good. But thats just me
Old 10-09-2009, 05:32 PM
Dempster Dempster is offline
Is it loose on shaft? Bearings gone out now or before letting it drag? Why did it crack ? Someone got wild clamping it in a vise too tight? It's not going to fire with the magnet dragging and bad bearings.
http://www.oldengine.org/members/die.../PetrolMag.htm
Old 10-09-2009, 07:35 PM
Its in good shape otherwise, but the mag cap was broke and a lot of crap got in between the rotor and coil possibly cracking when someone cranked it over. I cleaned it out got a new cap and cleaned the points and it fires beautifully. I was afraid that centrifugal force might make it come apart. I'll have to make sure its not loose on the shaft. I think I'd feel better with another rotor though, if I can find one. Thanks
Old 10-09-2009, 10:35 PM
Just make sure the magnetic rotor edges and inside laminations are smooth and free of any burrs. If it isn't loose I wouldn't worry about it but suppose you could fill the crack some with some JB weld and sand it smooth. That might help any metal on it from flaking out later on.
