5/8-10 Tap and Die
:wave: gang; Looking to beg, borrow or buy 5/8-10 tap and die for the Chase Shingle Mill...
this thread has 9 replies and has been viewed 613 times
Old 10-09-2009, 01:29 PM
Rick Strobel's Avatar
Rick Strobel Rick Strobel is offline
Images: 20
Question 5/8-10 Tap and Die
gang;
Looking to beg, borrow or buy 5/8-10 tap and die for the Chase Shingle Mill project.
Thanks for looking!
RickinMt.
Old 10-09-2009, 04:46 PM
Andrew Albrecht's Avatar
Andrew Albrecht Andrew Albrecht is offline
Images: 67
Default Re: 5/8-10 Tap and Die
Are you sure its not a 5/8-11 tap?
I Get My Corn From A Jar
Old 10-09-2009, 05:22 PM
Jeff in PA Jeff in PA is offline
Standard coarse thread is 5/8-11 ( as Andrew stated )
If you have what you believe to be a 5/8-10 bolt, take a new 3/4" coarse thread bolt ( 3/4-10 NC ) and lay the threads on top of each other. If they match perfectly, it is 10 threads per inch and it will a special ( meaning expensive) tap and die set.
If it's 5/8-11, that will be easy.
Do you need the die to cut new threads or just to clean/restore old bolts?
Jeff
Old 10-09-2009, 06:42 PM
Here's a 5/8-11 thread restorer hex die you can purchase for $12.71 ( plus shipping )
http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=72216074
We use this company ( MSC ) all the time at work. You can set up a personal account also.
Jeff
Old 10-09-2009, 09:30 PM
Mike Monnier's Avatar
Try Travers Tool Co. They are one of the few places that stock 1/2-12 taps and dies for us old iron folks. I believe they have a minimum order value, but those two items should be enough to cover if they have them.
The Following User Says Thank You to Mike Monnier:
Old 10-09-2009, 11:15 PM
DaveWachter DaveWachter is offline
Do you have a thread gauge if you have one check the threads then look for tap .an other thread to find is a 5 eiths twelve this thread is steam engine thread .your 5eights 10 thread could be a black smith thread.as such it maby hard to find a tap or a die to chase threads dave wachter thanks harry
Old 10-10-2009, 09:33 AM
Images: 20
Post Re: 5/8-10 Tap and Die
Definetly 5/8x10 guys as verified with a thread gauge
We need for both a chaser and making new threads.
Mike, I'll check out the above mentioned business.
Thanks guys;
Rick
Old 10-10-2009, 11:11 PM
After a LOT of hunting I found this site Ricky.......
Scroll to near the bottom of the page to the
60 UN THREADMILLS
STRAIGHT AND HELICAL FLUTE
heading:
http://mdmetric.com/prod/meda/202-207.pdf
The Following User Says Thank You to Craig A:
Old 10-11-2009, 11:41 AM
Images: 20
Thumbs up Re: 5/8-10 Tap and Die
Very big THANKS Craigster!!!
Found the die also and just to make the archive's, it's on page 182 (near the top) of;
http://mdmetric.com/prod/meda/181-191.pdf
U DA MAN
Rick
Old 10-17-2009, 01:37 AM
LundMachineWorks LundMachineWorks is online now
Banner Sponsor
MSC usually carries odd pitch tap and dies. I am not sure about series 10 though.
The Following User Says Thank You to LundMachineWorks:
