Onan BGE Generator- Oil Pressure Switch Question ?
this thread has 1 replies and has been viewed 3643 times
Old 10-12-2009, 12:36:13 AM
T Macgown T Macgown is offline
Default Onan BGE Generator- Oil Pressure Switch Question ?
Hello All,
After doing oil and filter change Generator would not start. It had been running fine before. It was suggested to by- pass the oil pressure switch. Is removing the lone wire from the switch considered by -passing. If not-- how does one by-pass the switch.
Thanks Much
Onan Emerald Plus 5000 Gen Set
Model 5BGEFA26100N
S/N 963577646
Volts 120
Amps 40
Fuel Gasoline
Hours 280
97 Winnebago Motor Home
Old 10-12-2009, 06:02:11 AM
lokay5 lokay5 is offline
Default Re: Onan BGE Generator- Oil Pressure Switch Question ?
The function of the oil pressure switch is to ground the points ( the negative - side of the coil) when there is no oil pressure. Disconnecting the switch wire at the coil will eliminate it from the circuit.
4.0 CCK Oil Pressure Sensor/Switch ? tang Onan Generators 15 08-16-2009 01:50:45 PM
Onan generator value question James06 Onan Generators 1 03-06-2008 02:15:48 AM
question-onan 15 kw pto generator NDcardoc Onan Generators 2 02-23-2006 07:11:44 PM
Onan Generator Question Joe Onan Generators 9 02-27-2004 11:25:33 AM
Oil Pressure Switch ibbob Generators & Motors General Discussion 7 01-11-2004 12:14:24 AM
