Valve seat grinding
this thread has 13 replies and has been viewed 4662 times
Old 10-12-2009, 08:08:38 PM
Bob Kurtz Bob Kurtz is offline
Images: 60
Default Valve seat grinding
Does anyone know of a good method or tool for grinding valve seats on an old Briggs WMI engine the seats are pitted ,just to much for valve lapping.
Thanks , Bob
Old 10-12-2009, 08:14:08 PM
Default Re: valve seat grinding
Bob
Go to your local Briggs dealer and buy a valve seat cutter. Easy to use.
Jim
The Following User Says Thank You to Jim Tremble For This Post:
Old 10-12-2009, 09:05:00 PM
Dennis Wyatt's Avatar
Dennis Wyatt Dennis Wyatt is offline
Images: 119
These are a little pricy but they work great! good luck!! http://www.flandersco.com/Images/PDF...%20Cutters.pdf
Dennis
The Following User Says Thank You to Dennis Wyatt For This Post:
Old 10-12-2009, 09:37:02 PM
Images: 60
Thanks for the information! i'll have to price out the tungston cutters ,and I'll check the briggs dealer tomorrow.
Old 10-12-2009, 10:02:01 PM
Images: 119
let us know how much the briggs cutters are. I may have to get one of those
Dennis
Old 10-13-2009, 06:43:50 AM
How much does the local automotive machine shop charge to do both seats?
Old 10-13-2009, 09:36:47 AM
Jerry Jerry is offline
Yo can also check with Neway They have some great sets
www.newaymfg.com
Old 10-13-2009, 05:22:52 PM
Dick DeBuse Dick DeBuse is offline
Neway sells a small engine set which will do most older Briggs as well as other engines. They provide OEM sets to many manufacturers. The valve refacer is very handy.
Old 10-13-2009, 09:06:49 PM
The Neway cutters work great, and the stones are replaceable. The valve seats in my Briggs model U were so bad, I thought I would have to replace them, but after a little work they cleaned up well. The only thing I had to have done was have the valve stems trimmed, which can either be done on a valve resurfacing machine with a stem attachment or at a local machine shop. I am missing the stem attachment for my machine, so I had my valves cut done by a local machinist.
A set of Neway cutters is a great investment, but they will run you about $200+.
~ Jonathan
Old 10-13-2009, 10:05:18 PM
Junkologist's Avatar
Images: 128
I got my Neway set at a local auction for $50. I love it.
Mike
Check out my engine videos at http://www.youtube.com/profile?user=Cletrac
Old 10-14-2009, 09:30:53 AM
K D Redd K D Redd is offline
Neway sets are expensive. Their basic valve seat cutter set now lists for $494.93 This set cuts 31 and 46 degree seat angles. If you want the set that cuts 15, 31, 46 ,and 60 degree seats it will set you back $734.17 These prices are from the Stens 2009 Master Catalog. I was lucky enough to have my Brothers Father-in-Law to give me a set he had gotten at an auction. This set is old. I would say the 60's. It has the price written inside the box. I think it was about 50 bucks then. I have told my Nephew that if he ever wants his Grandfather tool he is welcome to it.
Kent
Old 10-14-2009, 07:10:19 PM
SMertz SMertz is offline
Default Re: Valve seat grinding
You can sometimes find old valve seat grinders with stones at auctions. These will also work depending on the stone and pilot sizes, so long as it includes the facing tool for the stones. Stones will also easily do large engines the small neway/briggs set will not.
I happen to have both systems (bought the neway new from briggs, then found a blue-point/snapon stone set at an auction about 2 years later), so I use the neway for the smaller stuff, and the stones for larger. The carbide cutter set (neway) does a more consistant job and leaves a better, smoother finish.
Just my 0.02.
Old 10-14-2009, 07:33:05 PM
Bob Krummel Bob Krummel is offline
Racing go kart shops sell a 31 and 46 degree cutter with a 1/4 inch pilot Neway kit for about $150 or there abouts. Check eBay. You could maybe make your own pilot shafts to match the valve stem diameters of the older briggs. I got a used kit on eBay with several different pilot diameters for less than $100.
Old 10-14-2009, 07:54:54 PM
In reply to smertz when I worked at the machine shop training school we had several different valve grinders that used stones plus the Newway. If your stone finish is not that good compared to the carbide are you doing stellite or other alloy type valves? You may have the wrong sone. Where I sub at school they use the New-Way for small engines but stones for everything else. Remember soft stones are used when grinding hard seats.
Valve seat grinding Briggs model 6 will s Small Air Cooled Gasoline Engines 5 03-21-2008 06:34:03 PM
valve grinding questions CGBusch Antique Gas Engine Discussion 8 04-16-2007 11:33:13 PM
valve grinding gene w Machine Shop and Tool Talk 0 04-04-2007 07:01:21 PM
Valve Grinding? DippyNo12 Antique Gas Engine Discussion 12 11-06-2005 11:11:22 PM
Seat Grinding stone d.j.baisch Antique Engine Archives 8 01-23-2004 10:11:13 PM
