Go Back   SmokStak > SmokStak® General Discussion > Smoke, Flames & Gas (Off Topic)
electric motor to generator?
can i take a electric motor and convert it in to a gennrator and how can i do...
this thread has 5 replies and has been viewed 348 times
Old 10-17-2009, 02:01 AM
Christian Berlin's Avatar
Christian Berlin Christian Berlin is offline
Question electric motor to generator?
can i take a electric motor and convert it in to a gennrator and how can i do it?
Cant wait to get my 6hp fairbanks running
Old 10-17-2009, 09:35 AM
Clifton Clowers Clifton Clowers is offline
Default Re: electric motor to generator?
Here is one site that I've used in the past, It does work!
If you want to use a different kind of motor, search the web or
youtube. regards , clifton
http://www.qsl.net/ns8o/Induction_Generator.html
Old 10-17-2009, 11:31 AM
jht1057 jht1057 is offline
Christian,
Check out www.Otherpower.com, there are a lot of ideas there for using your motor idea.
Jim
The Following 2 Users Say Thank You to jht1057:
Old 10-17-2009, 06:22 PM
Sky's Avatar
Sky Sky is offline
Images: 45
I dont have a real good idea of how acurate this is but i use to hear alot of the old time electrical engineer's that had a saying as the fallowing:
A generator can make an electric motor, but not a very good one and a motor can make a generator, but not a very good one.
I'd say the use of the design has alot to do with it. Im not an electrical engineer so i cant go into spacifics. If there's any truth to this at all.
20th Century Machine's http://www.youtube.com/user/VintageClassic1
Old 10-18-2009, 01:57 AM
Exclamation Re: electric motor to generator?
A brush type motor, with permanant magnets can be both motor and generator. Most battery operated childs riding cars use a 12 volt motor. When the car gets busted, or outgrown, salvage the motor, and drive it with an engine. It will make power. For years, Wisconsin, Kohler and others used Delco-Remy starter-generators on their engines. The generator acted as a motor to start the engine, and once started, the engine turned the motor, and made it a generator, to recharge the battery. It was ineffecient, but it did the job, and the units lasted a long time!
Andrw
Old 10-18-2009, 06:38 AM
Jim Conte Jim Conte is offline
Pumped Storage hydro electric plants use motor generators that are equally efficient either way.
I helped recondition and upgrade the units at Muddy Run in Pennsylvania.
http://www.voithhydro.com/media/VSHP...rage_72dpi.pdf
http://www.exeloncorp.com/ourcompani...ons/Muddy_Run/
http://www.boilersaver.com/
The Following User Says Thank You to Jim Conte:
Electric motor 1 phase / 3 phase generator? Isaac-1 Generators & Motors General Discussion 5 10-08-2009 06:30 PM
Electric motor or generator casting set Clif Roemmich Scale Model Engineering 6 12-24-2008 10:49 AM
Electric motor Help Andrew Albrecht Generators & Motors General Discussion 4 03-29-2005 04:35 PM
Electric Motor Dominick Generators & Motors General Discussion 0 01-26-2004 02:39 PM
Old electric motor? Jack Cahill Vintage Toy Steam Engines and Motors 2 03-18-2001 01:01 PM
