Can antique wood columns be cleaned up in a metal lathe?
I got 8- 5' long by 11" diameter tapered porch columns that PO messed up with a grinder/sander. ...
this thread has 3 replies and has been viewed 304 times
Old 10-18-2009, 12:43 PM
mschreiber mschreiber is offline
Default Can antique wood columns be cleaned up in a metal lathe?
I got 8- 5' long by 11" diameter tapered porch columns that PO messed up with a grinder/sander. there are solid with a hole bored thru lengthwise. i can't find anyone with wood lathe or that experience to answer. looks to me that a 1/8" max should be taken off. see pics. thanks.
ID:	65095   Click image for larger version
ID:	65096   Click image for larger version
Old 10-18-2009, 03:37 PM
Tanner Remillard's Avatar
Images: 10
Default Re: Can antique wood columns be cleaned up in a metal lathe?
I dont see any reason why not. I have turned wood in a metal lathe before. But im not a wood turning expert by ANY means, so probably should get more advise
Old 10-18-2009, 04:50 PM
ehpower2 ehpower2 is offline
personaly i wouldnt want to because if its a metal lathe they have all that oil and coolant around and i personaly wouldnt want to mess up my nice toys
Old 10-18-2009, 05:04 PM
jht1057 jht1057 is offline
mschreiber,
I use my lathe and mill frequently for wood projects, works great, and I have found the wood chips and dust actually help clean up the old oil and debris on the machines. A good going over with a shop vac and some fresh oil on the moving parts and I'm off and running on metal again.
Jim
What have I got here, Wood or metal lathe? Randy Hart Machine Shop and Tool Talk 7 09-25-2009 11:37 PM
Pratt & Whitney Metal Lathe 1868 genexreptiles Machine Shop and Tool Talk 3 08-30-2009 12:41 AM
Whats this antique metal brake for? JKWidener Machine Shop and Tool Talk 6 07-19-2008 09:23 AM
A bit of metal and wood working I've wanted Paul Spence Antique Gas Engine Discussion 22 06-09-2007 11:41 AM
Battery box metal or wood Don Nelson Antique Engine Archives 3 11-29-2003 09:28 AM
