Wico Ek wiring
Does it matter which 2 of the primary wies are linked together as long as the other ends one goes...
this thread has 4 replies and has been viewed 239 times
Old 10-20-2009, 06:26 AM
AUSDOK AUSDOK is offline
Default Wico Ek wiring
Does it matter which 2 of the primary wies are linked together as long as the other ends one goes to the condenser and the other to the points. Is there a wiring diagram available Thanks Ausdok
Old 10-20-2009, 08:51 AM
Tom Martin Tom Martin is online now
Default Re: wico Ek wiring
There should be two wires from each coil. One is an insulated wire coming from near the bottom of the coil and the other is just a stiff wire extending about 1/4" from the front of the coil near the top. The two short stiff wires are connected by a coil spring with an insulating cover. The insulated wire lead from the left coil attaches to the points assembly, along with one capacitor lead. The insulated wire lead from the right coil attaches to the frame of the mag, along with the other capacitor lead, to the screw in the frame below the right coil.
Old 10-20-2009, 04:03 PM
Default Re: Wico Ek wiring
Thanks for your quick reply Tom ,with the othe two lugs from the bottom of the coil are these soldered together with a wire link. what is the best way to tell the difference from the right and left coil.I know this may sound stupid question but I want to getit right. Thanks Rudy
Old 10-21-2009, 06:58 AM
Rudy:
I looked at a couple of old EK coils last night, and there were two wires coming from the bottom of each coil, with one wire being shorter than the other. The short leads were connected together, and the longer ones went to the points and ground. I don't think that there is anyway to get the coils confused if they are made like the ones I have. The short, stiff leads at the top can only go one way if the coil spring jumper is going to work.
Old 10-21-2009, 07:13 AM
Thank Tom I will spend some more time on it tomorrow Rudy
Wiring up PE-95K 120/250 Jim Kinler Generators & Motors General Discussion 7 08-27-2008 09:04 PM
Need help with wiring 120 over to 240 rmeche Onan Generators 3 12-21-2007 11:22 AM
I need help with wiring MarkGreco Small Air Cooled Gasoline Engines 3 04-17-2006 10:49 PM
NEed wiring help Graig Onan Generators 0 08-30-2005 01:51 PM
Wico EK wiring Larry Kastens Antique Engine Archives 6 08-27-2002 05:29 PM
