Square stock
I was wondering if there is a safe and accurate way to chuck up a peice of square stock in a 3 jaw...
this thread has 6 replies and has been viewed 425 times
Old 10-25-2009, 06:49 AM
JKWidener's Avatar
JKWidener JKWidener is online now
Images: 26
Default Square stock
I was wondering if there is a safe and accurate way to chuck up a peice of square stock in a 3 jaw chuck? Need to turn a small peice about 1" in diameter.
It takes only a moment to say I love you and a lifetime to say goodbye.
Old 10-25-2009, 09:32 AM
Default Re: Square stock
weld it to a piece of round stock
The Following User Says Thank You to Ed Radtke:
Old 10-25-2009, 09:39 AM
joneg joneg is offline
make a sleeve that just slides over the square stock and then saw thru one side to split it. chuck on the sleeve
The Following 5 Users Say Thank You to joneg:
Old 10-25-2009, 11:06 AM
Good one.Ill have to remember that.
Old 10-25-2009, 01:23 PM
Jeff in PA Jeff in PA is offline
joneg,
brilliant, easy idea.
Jeff
Old 10-25-2009, 02:02 PM
OTTO-Sawyer's Avatar
Thumbs up Re: Square stock
Make your sleeve with at least 1/4-3/8 wall thickness so you can tighten the 3-jaw securely without distorting it. 1/2 inch thick would be better yet.
Bore it so your square stock barely fits in on the points and then take a light cleanup pass on the OD before you take it out of the chuck to make sure it's concentric to the ID if you want your square stock to run true. If the piece of round stock is already cut to length so you can't bore & turn in one setting, then take a punch and put an alignment mark at jaw #1 so you can get it back in the same alignment every time.
If you have .005 runout in your chuck and you rotate the sleeve 1/2 a turn from where you bored it you will end up with .010 runout in your square stock !
The Following User Says Thank You to OTTO-Sawyer:
Old 10-25-2009, 10:42 PM
NAMPeters NAMPeters is offline
Images: 9
Get a four jaw chuck. In the long run you will be glad you did.
Neil Peters
Phoenix/Tonopah AZ
When hunting, a broken part is better than no part at all.
Oil stock show andy fetko Antique Gas Engine Discussion 0 07-20-2009 02:35 PM
Shim Stock Sky Antique Autos and Trucks 18 06-24-2007 02:35 AM
Square head bolts and square nuts hitmis1 Antique Gas Engine Discussion 6 01-26-2006 12:57 PM
Stock tractor David Parfitt Antique Tractors - Old Iron Lugs, Cleats and Tracks 1 09-21-2005 09:35 PM
shim stock Eric M Antique Engine Archives 8 09-26-2001 01:40 PM
