Crazy belt changing...BQhfcdQf1QA&feature=player_embeddedthis thread has 12 replies and has been viewed 593 times
HAaa...Thats a pretty neet trick.
20th Century Machine's http://www.youtube.com/user/VintageClassic1 |
Definetly got to watch them fingers :eek
I have a friend that has had a VW garage for over 30 years, I thought I saw all the great VW tricks...............................I was wrong.
I'll have to pass this on to him. Jim |
I did notice that he still has all his fingers..........for now.
![]() Definately a cool trick. |
Wouldn't he still have to adjust the belt tension if he actualy put a new belt on?
Richard W. |
That's not a WHOLE lot different than moving the belt on a set of step pulleys........
http://www.youtube.com/cahartley7 |
The Following User Says Thank You to Craig A:
How many time will he be able to do that without injury? Would you take that risk? What happens if that screwdriver decides to come flying out of there like an angry dagger?
Would your mother say "...You're going to put an eye out like that!..." She'd be right! I once had a VW with a tempermental starter. Found that if I had someone hold the key in the Start position, I could give the generator pulley a little nudge and it would crank over. This was all good until I got a finger in the belt one time. The final toll - Broke the tip of my index finger. The X-ray looked like a pencil with the end of the lead broken off. I got a new starter very shortly after that. |
just my observation,I think he put the same belt back on,a different belt and the tension would be different.You adjust them belt's by taking off the gen pully and changing the shim's.Like it say's just a "trick",and a dangerous one at that!!
The Following User Says Thank You to grub54891:
The belt looked rather loose.
A tight belt surly would have put that driver thru his head. A friend tried that, many years ago, and the generator pully bent. The belt took the driver out of his hand, and after several revolutions, sent it thru the hood and onto the roof of his house. By the way, broke 3 fingers on the first turn
, and his wrist on the second . The third was the charm, it got launched!![]() Andrew |
Smooth-stupid, but smooth....
| Changing oil in a Briggs 5S! | Ottawa | Small Air Cooled Gasoline Engines | 3 | 07-12-2009 10:07 AM |
| Changing polarity | flasks | Generators & Motors General Discussion | 2 | 01-20-2009 02:58 PM |
| MEP 003 frequency crazy | Jiggy | Military MEP and Aircraft Gen-Sets | 12 | 01-15-2009 01:33 PM |
| CRAZY Prices | Craig A | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 7 | 04-10-2005 08:56 AM |
| Changing your USER NAME | Harry | How to use this web site: | 0 | 01-25-2005 08:15 AM |
