Gib Key slide hammer
Heres some pictures of a slide hammer converted to gib-key puller, not pretty but works.
this thread has 4 replies and has been viewed 494 times
Old 10-28-2009, 12:33 AM
Wayne H. Olson Wayne H. Olson is offline
Default Gib Key slide hammer
ID:	65840   Click image for larger version
ID:	65841   Click image for larger version
Old 10-28-2009, 12:59 AM
Default Re: Gib Key slide hammer
Looks like it worked.
I often drill and tap the key and screw a stud in, then use the puller.
Richard W.
Old 10-29-2009, 12:01 AM
Joel Sanderson Joel Sanderson is offline
I'm lost. How does it work? Does the tail of the gib key stick out one of the holes and then the screw is tightened to extract it? Is that it?
Old 10-29-2009, 09:15 PM
aametalmaster aametalmaster is offline
Cool Re: Gib Key slide hammer
I have a nice one too. That was a much needed item when i was a Millwright trying to get a 1" sq key 7" long from a 900 ton punch press...Bob
Old 11-03-2009, 09:58 AM
rleonard rleonard is offline
Here is one I made to pull the keys on my Listers. I have used it many times and it works great.
Bob
ID:	66233   Click image for larger version
The Following 4 Users Say Thank You to rleonard:
If you like Mr Otto's slide valve... joneg Scale Model Engineering 19 10-31-2009 02:43 PM
Slide valve timimg BobRR Stationary Steam & Traction Engines 6 02-01-2008 11:09 PM
Crosshead Slide steamgas Stationary Steam & Traction Engines 16 10-27-2007 09:14 PM
The Art of a slide-valve. Pix John Hammink Antique Engine Archives 0 06-02-2004 06:05 PM
need info.on a slide valve tex holliday Stationary Steam & Traction Engines 1 02-23-2003 05:00 PM
