DLTX 53 Carb. For JD A
are they hard to rebuild. i have one in pretty bad shape. it has set for 30 years and it was full...
this thread has 3 replies and has been viewed 111 times
Old 11-01-2009, 01:24 AM
hardknocks hardknocks is offline
Default DLTX 53 Carb. For JD A
are they hard to rebuild. i have one in pretty bad shape. it has set for 30 years and it was full of rust. I put it in a acid bath and it came pretty clean .
Old 11-01-2009, 02:22 AM
Default Re: DLTX 53 Carb. For JD A
It's too late to go into that right now but please check some of the "Similar Threads Chosen at Random" just below these messages.......
There's a thread there about a rebuilding a DLTX 18 carb for JD.......
Old 11-01-2009, 12:29 PM
ronm ronm is offline
Did you have all the little brass plugs out when it was in the acid bath? If not, you need to get them out & give her another trip through the bath....then get the long drills or ream the passages out w/heavy wire-they have to be open, or it won't run....also, you have to get the nozzle out of the center, you won't believe the crud that's in there.
Old 11-03-2009, 07:36 AM
i just purchased a rebuilt one. didn't want to fool with it.
John Deere DLTX problem Larry Holderman Antique Tractor Talk 17 07-08-2009 10:29 PM
DLTX 18 compared to DLTX 10 - the saga Wayne Schumack Antique Tractor Talk 8 02-28-2009 01:25 PM
Rebuilding a DLTX 18 Carb for JD Randy L Peterson Antique Tractor Talk 5 07-05-2007 02:24 PM
John Deere DLTX 63 for a D 1947 Ron Davis Antique Tractor Talk 3 11-26-2006 12:30 AM
John Deere DLTX carb ssimntih Antique Tractor Talk 4 05-16-2005 12:22 AM
[IMG] code is Off
