Freeing up Field Marshall tractorwe spent yesterday trying to free up an old field marshall tractor but it wont move the crank turns...this thread has 4 replies and has been viewed 302 times
we spent yesterday trying to free up an old field marshall tractor but it wont move the crank turns fine but the piston is solid we left it to soak for a month and heated yesterday and hit it but still no joy any idears?
Hi how does the piston & bore look from the exhaust port. If it looks at all ruff in there there is only one thing for it. That is block off & in to a press. If you try to force it you could end up very sad
this might sound simplistic but time and patience are your best tools when it comes to a stuck engine.
i unstuck a 1947 Farmall cub engine a few years ago , took me about 3 months took the head off and filled the bores with my favorite weasel juice, put the head back on loosely and took a look inside once in a while when i was close by. after about 1 month i noticed the juice level getting lower on a couple of pistons so i added more juice . now i started to pull up on the hand crank every morning before work and rock the tractor back and forth in gear. one morning before work i pulled up on the crank and by jesus if she didn't move a little so i took a BIG screwdriver and turned the starter ring gear back the opposite way. now this was getting fun , she was on the move and i was winning the battle between man and inert rusty iron. i also paid close attention to the valves which are in block(she's a flathead) didn't want to bend them all up so i juiced them up good too. long story short ; freed the engine up using more brain then muscle and ended up with a nice snow pushing machine for cheap. good luck with your project Dan |
Along with the weasel wizz on tops of the piston I put a 5 gallon bucket on the crank handle and fill it with rock/sand/steel scrap. It adds some pressure to the pistons and you will be happy to go out and see the bucket sitting on the ground.
Found this one a while back. Never had the oportunity to try it yet, but I can't see why it wouldn't work.
http://www.rustyiron.com/engines/piston/index.html |
| Freeing up a 6hp Titan | Jon Rozevink | Antique Gas Engine Discussion | 5 | 06-08-2009 05:02 PM |
| George Catlett Marshall, The Marshall Plan | Brothers Clemens | Smoke, Flames & Gas (Off Topic) | 7 | 06-12-2008 03:44 PM |
| Oil Field Engine in Tractor on Prony Brake | Bruce E. Babcock | Oil Field Engines | 1 | 08-30-2007 11:17 PM |
| Marshall Colonial Oil Tractor | Randy Kvill | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 6 | 04-30-2007 11:57 AM |
| Field Marshall Diesel | Dustin D Ehli | Vintage Diesel Engines | 6 | 04-19-2007 10:52 PM |
