No Spark
I have a maytag model 92 and it has a weak spark.Help Please
this thread has 3 replies and has been viewed 147 times
Old 11-02-2009, 10:28 PM
Dickie W. Russell Dickie W. Russell is offline
Default No Spark
Old 11-02-2009, 11:52 PM
Arlie Levy Arlie Levy is offline
Default Re: No Spark
Remove the flywheel clean the points. Possibly replace condenser. Do not take the points out. By moving them it will mess up the timing. To adjust them use a little wrench and adjust the moveable point. About
.020 is fine. To remove flywheel loosen the big nut and back it off so it is flush with the end crank shaft. Then put a large screw drive between flywheel and the engine and pry gently while hitting the end of the crankshaft with fairly hard. A brass hammer is best so you don't mess up the threads.
Old 11-03-2009, 10:01 PM
Bill Geyer's Avatar
Images: 11
Most of the Maytags I have worked on have weak spark. After doing Arlie's procedure if the spark is still a little weak you might try setting the spark plug gap smaller. First .025, then .020, even .018 can make a weak mag run a Maytag.
May the Stak be with you
Bill
Old 11-05-2009, 01:49 AM
Dempster Dempster is offline
Try a new condenser too. One for a model A Ford works.
B & S FH no spark Fredd248 Small Air Cooled Gasoline Engines 2 04-14-2009 10:21 PM
No spark candersen Antique Tractor Talk 5 03-15-2008 08:31 PM
72-D No spark "TheToolman" Maytag Engine Collectibles 13 03-03-2008 07:41 PM
No Spark Geo P Magnetos, Ignition Coils and Spark Plugs 0 05-09-2006 05:51 PM
1 1/2 hp M HAS SPARK Allen L Fry Antique Engine Archives 0 03-07-2002 02:34 AM
