Lister Petter AC1?
this thread has 6 replies and has been viewed 3816 times
Old 11-21-2009, 03:29:28 PM
Chris1021 Chris1021 is offline
Default Lister Petter AC1?
i have a Lister Petter AC1 6.5 HP 3600 rpm my ? is when starting i have to hold the gov. lever up to almost the stop position to get it up to rpm and to stop smoking once the engine is warm and up to rpm i can let go and it runs fine is this normal or is there some problem ?
Old 11-21-2009, 03:39:23 PM
ListerDiesel's Avatar
Default Re: lister petter ac1 ?
How old is the engine, has it had any regular oil changes and what is its previous history before you came upon it?
There is an excess fuel arrangement for starting, have you followed the operator's manual procedure?
Peter
Old 11-21-2009, 03:58:41 PM
it is @ a 1992 with 1086 hours i dont know abought the oil changes before i got my hands on it i was a old military heater that the wonderfull us gov. destroyed the heater before geting rid of it i changed the oil a few times i use rotella T 15w40. and there is no fuel arrangement that i have to use to start it
Old 12-20-2009, 11:24:36 AM
topcat topcat is offline
Could be governor unit sticking./
Works by ball bearings revolving in a Or worn bearings cone when engine spins and is directly linked to run/ stop button.You have to remove crankcase to locate it but is easy job.
This controls the fuel supply from the pump via the governor linkage mechanism connecting to the pump slide on top of the pump.
There is also a governor speeder spring on the side of the engine below the exhaust.This is for fine tuning.
The springs in here are different depending on the speed you need the engine to run, so make sure you buy the correct spring from Petter if you need one.
Old 12-20-2009, 11:51:06 AM
Sorry got my english wrong.
Reply should start - Could be governor unit sticking or worn bearings!
It works by ball bearings revolving in a cone when engine spins ....,.,..............
To summarise - this revolving of the bearings in the cone controls the fuel supply from the pump and therefore keeps the engine speed to the desired revolutions.
Old 12-24-2009, 11:00:26 PM
Default Re: Lister Petter AC1?
thanks will have to check that out
Old 12-25-2009, 05:26:42 AM
Roland Hayes Roland Hayes is offline
Try another injector, preferably one from another engine that is running correctly, good luck. Rol.
Lister Petter Sr2 Ventor Smokstak Down Under 0 11-16-2009 11:05:38 AM
Lister-Petter AA1 Help devil1dog Vintage Diesel and Oil Engines 2 10-20-2009 04:31:14 PM
Lister and Petter Engines quickies Vintage Diesel and Oil Engines 0 08-16-2007 10:39:48 AM
Lister Petter BA1 Shadow B Vintage Diesel and Oil Engines 1 12-22-2005 02:45:39 AM
Lister Petter 25&30 Kw gen set Andy H Vintage Diesel and Oil Engines 0 11-12-2005 06:06:19 PM
