Best way to clean fuel tank
this thread has 15 replies and has been viewed 43922 times
Old 11-28-2009, 02:58:51 PM
Twin34 Twin34 is offline
Default Best way to clean fuel tank
What's the best way to clean a fuel tank I've read different ways in doing it, what's way do you guys/gals use?
Old 11-28-2009, 03:41:07 PM
Default Re: Best way to clean fuel tank
I fill it with gravel and water and shake it.
Richard W.
Old 11-28-2009, 04:27:00 PM
JHFoster JHFoster is offline
I use a chain tied to a wire (kept outside the tank) to make it ease to remove.
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Old 11-28-2009, 04:46:54 PM
Exclamation Re: Best way to clean fuel tank
I use Acetone and a couple of handfuls of brass 1/4x20 nuts and bolts. (brass = no sparks). Shake well, dump out residue, rinse with plenty of water. Dump out water, repair any leaks, rinse again with water. Rinse with Kerosene to get rid of water, and check for leaks. If there are any, kero will find them!
Old 11-28-2009, 08:47:19 PM
Gunny Gunny is offline
Pour in 2 packs of steel BB shot.
Mount tank in a paint shaker and shake it for about 5 minutes.
Dump out BBs ans rust/trash. Blow with compressed air.
Coat inside of tank with Kreme or other similar product made to coat the inside of fuel tanks.
Old 11-28-2009, 09:48:57 PM
EdDarowski EdDarowski is offline
When rinsing the tank, after one of the above recommended cleaning processes, dump your rinse water into a white plastic bucket. That way, you can see when the rinse water is clean of all flakes of crud. Ed
Old 11-28-2009, 11:16:12 PM
K D Redd K D Redd is offline
I use a pressure washer. If you do not have one a car wash would work.
Kent
Old 12-19-2009, 12:22:13 PM
Thiel's Avatar
Thiel Thiel is offline
Just as I thought I am ready for Lee Pedersen's Tank sealer in my ACME gastank (after days of skake, rattle and roll) , I was going to use compressed air to blow out the last remains of any leftover particles and water.....
I noticed air bubbles from one of the two, about 4" cover holes on top.
Well, after closing off the drain and filler neck and continuing with compressed air, guess what came flying through my garage?
At least I have now a fairly good size access to scrape out plenty of sludge, maybe I hire the neighbor kind (smaller hands ). But seriously, how are these manholes sealed backup? Just a press fit?
BTW, the tanks weight is approx. 125lbs (3gal), quite heavy.
Attached are some pictures, the last one shows the inside, which looks like pictures I took while spelunking in the Mammoth Caves in Kentucky.
Old 12-21-2009, 08:17:25 PM
learnhart learnhart is offline
I took mine to a raditor shope. they cleaned it great.
Old 12-21-2009, 10:36:47 PM
Kris Golden Kris Golden is offline
white vinegar will remove the rust and is non toxic. Its a little slower than muratic acid but it won't rust back immediately like muratic will. On tanks that had water in the bottom and rusted only the bottom, I have often left them alone after cleaning. On tanks that were badly rusted all over, After cleaning, I treat them with "U.S.Tank" [or U.S.A. Tank] from the POR-15 people. Makes the inside look freshly galvanized and is permanant.
Old 12-28-2009, 12:07:41 AM
yquem yquem is offline
If you want to get fancy, I rigged up an electroytic device, putting a railroad tie into the tank as the positive electrode, (suspended so as not to contact the tank), with the tank filled with water and baking soda, battery charger negative connected to tank.
This will convert all the adhered rust back to metal, and push the stuck goo away from the metal.
I had a tank where the forty-year-old gas had turned to paste and this eventually freed it all up so I was left with bare metal.
The Following User Says Thank You to yquem For This Post:
Old 12-28-2009, 06:14:37 AM
Rich Mc Rich Mc is offline
To YQUEM;
What is the ratio of water to baking soda that you use?
Rich
Old 01-01-2010, 01:29:56 AM
I think its something like 5 tablespoons in five gallons, so it doesn't take much, and more isn't better. I got the recipe off the internet from a site that uses it to derust cast iron pans.
Old 01-01-2010, 02:35:42 PM
ar2stp48 ar2stp48 is offline
Several way have been mentioned and probably all work.
I have always used a hand full of staples, fence staples frome the hardware store--they cut better than rock, chain or bb's. Staples, a little liquid detergent, water, and shake well. Dump the water and staples and rinse several times. Drain all the water possible and then pour in a couple bottles of alcohol--rubbing kind from Wally World. Alcohol will get the last of the water in tank. Dry tank in sun and you are ready for sealer. I have had great results with product called Red Coat from local auto supply.
Good luck
Old 01-01-2010, 03:52:08 PM
The product is called Red-Kote. I have used it too. I bought a quart can to use on some small pony motor tanks. I like the fact that you can put too much in, splash it around for complete coverage then and pour excess back into the can for use on other tanks. It is a single component coating so no mixing, just clean tank properly and dry completely before treating it.
Old 01-29-2010, 10:12:33 PM
gerdberg gerdberg is offline
Check out http://www.por15.com/ It's supposed to be the best stuff out there.
I have a kit for my Tractor gas tank but haven't used it yet.
How To?? Clean Contact Points? Clean Exhaust Port? enginesilo Maytag Engine Collectibles 4 06-07-2008 02:53:41 AM
How to clean a diesel fuel tank? Jim Davis Generators & Motors General Discussion 5 08-14-2007 09:19:09 PM
Clean Gas Tank Tom Herd Antique Gas Engine Discussion 4 10-13-2005 04:23:45 PM
CT4 fuel tank Ed Deis Antique Engine Archives 0 06-27-2003 08:12:09 PM
