| Unidentified Engines Post your photos and questions about your unknown engine and look for answers here. |
IHC-mini mixer mystery- Tom Thumb or Titan starter engineI cant figure out what IHC engine this little bronze carburettor came off off. It has a tiny 5/16...this thread has 3 replies and has been viewed 1269 times
It has a tiny 5/16 inch bore, mounts with two 1/4-20 bolts spaced 1-3/8 inches centre to centre and is approx. 5 inches tall and 5-3/4 inches long, overall. It is marked "178VG" on the removable filter housing and "1708D" on the body. Any ideas? |
i think it is PART of a carb for an ihc 10 20 tractor.
I thought it looked similar to the 10/20's carburettor so I looked at one i have sitting in the fence-row. it is similar to the top half of that one (and another I found on the shelf), but both of those carburettors have the high speed screw on the top where this has a mounting flange and the fuel flows thru the bottom of the carburettor (where this has its high speed jet adjustment located) before making a 90 degree turn to go into the intake manifold on both of the 10/20 carburettors.
This thing appears to be an up-draft with a paltry 5/16ths venturi that would strangle even a 10/20 for fuel! Is there another variation of the IHC mixer for tractors or stationary engine/power-units that maybe used a float bowl bolted up at the bottom like this??? |
My Titan starting engine has a side draft carb. Some of the gas starting IH Diesel tractors had a really small carb as they only idled on gas. This seems a bit small for that though.
| Mystery mixer | Max Cox | Unidentified Engines | 1 | 11-05-2009 04:52 PM |
| Titan 10-20 Mixer | SproutW | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 18 | 02-09-2009 09:09 PM |
| mystery mixer What does it fit??? | B.L. Rodenkirch | Antique Gas Engine Discussion | 0 | 06-25-2006 09:55 PM |
| mini jaeger mixer | maxx | Antique Gas Engine Discussion | 1 | 05-25-2006 11:05 AM |
| Mixer Mystery | Jack Lester | Antique Engine Archives | 7 | 08-19-2002 09:23 PM |
