Kohler Generators
Kohler Generator Starting and staying running problem
this thread has 1 replies and has been viewed 3971 times
Old 12-06-2009, 11:49:18 PM
cherylstommy cherylstommy is offline
Default Kohler Generator Starting and staying running problem
Thank God for Forums of all kinds! Especially Smokestak! . I have an '89 RV with a Kohler 7cm21-RV generator that is hard starting and wont stay running. If I manually play with the choke and throttle, I can make it run for a little bit, but it soon dies if the start switch is released. I know it probably needs a carb overhaul, but the dying with releasing the start switch is new to me due to generators are new to me. I have been a MasterAuto tech for 20 years now. A little help in the right direction would be much appreciated. New things are fun!
Tom
Old 12-07-2009, 09:21:07 AM
K D Redd K D Redd is offline
Default Re: Kohler 7cm21-RV Generator Starting and staying running problem
I do not know much about Kohler but it may not be making power. On an ONAN if it will not stay running you need to see if the generator end is making power. Also check for oil pressure if engine is so equipped. If you have oil pressure figure a way to hot wire and check to see if the generator section is making power.
Kent
Onan Emerald RV generator starting problem hurst01 Onan Generators 5 09-03-2009 06:27:17 PM
Kohler 17,5KW Diesel generator A/C problem bowenar Kohler Generators 1 05-22-2006 11:52:39 PM
7.5 generator starting problem Don Kreutzer Generators & Motors General Discussion 8 01-01-2006 01:00:05 PM
Kohler generator problem Duane Bettner Kohler Generators 4 09-28-2004 09:57:12 AM
kohler generator starting weird mike collins Kohler Generators 1 06-04-2003 10:58:16 AM
