Favorite way to free stuck valves?
this thread has 13 replies and has been viewed 11611 times
Old 12-08-2009, 07:47:51 PM
A Martinson A Martinson is offline
Images: 39
Default Favorite way to free stuck valves?
On the 16-30 TC all of the exhaust valves are stuck, what is everyone's favorite method? For now, I'm just going with patience and lots of penetrating oil.
Old 12-08-2009, 07:57:39 PM
ajs2744TC ajs2744TC is offline
Default Re: Favorite way to free stuck valves?
Penetrating oil and a brass tip hammer, If that dont work...DYNAMITE !!!
The Following User Says Thank You to ajs2744TC For This Post:
Old 12-08-2009, 08:29:11 PM
Eric M. Eric M. is offline
PB Blaster, Kroil, and a brass hammer. Just keep tapping away. They should come loose eventually. I'm in the process of working on a Bates 35 tractor that had water standing in one cylinder and all 4 exhaust valves were stuck. In less than a week, all 4 were loose.
The Following 3 Users Say Thank You to Eric M. For This Post:
Old 12-08-2009, 08:40:19 PM
Images: 39
Also note, this is a flathead engine. Where should I tap at the valves?
Old 12-08-2009, 08:54:00 PM
I quit using straight penetrating oil a long time ago as it evaporates and any gains are lost.
I switched to a, roughly, half and half mix of penetrating oil and brake fluid.
Don't tap on the valve heads directly. Use a piece of brass to transfer the hammer taps.
Patience is an admirable way to attack that problem......
The Following 7 Users Say Thank You to Craig A For This Post:
Old 12-08-2009, 09:54:38 PM
Rick Schmitz Rick Schmitz is offline
I've had success heating them up a little with a torch and then squirting on some kroil.
The Following User Says Thank You to Rick Schmitz For This Post:
Old 12-08-2009, 11:50:20 PM
Mr Martinson!
As others have said - PATIENCE!
It took them a long time to stick up - you don't need to get them loose the first day. Some tender love taps and lots of soaking. They'll come out.
G.
Old 12-09-2009, 12:35:25 AM
turbo turbo is offline
Look at it this way, The tolerance between the valve and the guide was small enough to stick with rust. The rest of the engine must not be too worn out!! I have one engine that I think could soak in calcium cloride for ten years and still be able to turn over
Old 12-10-2009, 08:05:26 PM
There is a tricky and a questionable way. Use a very light acid and a small brush to apply. Wrap a rag around each valve stem and watch carefully. Be sure to make sure valve guide doesnt react to this. Muriatic might be a tad strong but Hydrochloric is weaker or try citric and just be careful. Note: This should be a last step and read label carefully and dilute. DO NOT drink it in celebration!!!
Old 12-11-2009, 05:48:34 AM
Richard Sturdy Richard Sturdy is offline
Actually, muriatic acid is just an old-fashioned name for hydrochloric acid (HCl)
Tricky Dickie
Old 12-11-2009, 12:22:28 PM
Robert Holt Robert Holt is offline
Hi all, just take the head off and do the job correctly you can then check and clean the vales up, re cut the seats and reface the head ........after all the waiting for them to free off you will have done the job and enjoy driving your old girl to the pub ..........R
The Following User Says Thank You to Robert Holt For This Post:
Old 12-11-2009, 12:23:21 PM
Rene Elliott Rene Elliott is offline
I've used "naval jelly" which I understand is just a acid, (possibly hydrocloric?) on the YXC3 Hercules in my Linn, which had a lot of water in the cylinders, steel block aluminum pistons, and embarassed to admit after 20 years of having the heads off and covered with a tarp, the cylinders are mostly cleaned out, but a few of the valves still tight to the block but honestly have not tried tapping with a hammer yet, it looks 100% better than when I started. Maybe while the bees are quiet I can get in and mess with it. (Then there are the snapped off cylinder head studs to deal with....). I tried using Coca-cola once to unseize an old V8 we had then learned afterwards that can glue things better than antifreeze if you don't flush out EVERYTHING. Somethings you believe as a teenager (30 years ago) you realize later were pretty stupid but someone somewhere had a good laugh over it.
Old 12-24-2009, 07:01:01 PM
markw1954 markw1954 is offline
Muriatic acid is a diluted form of Hydrochloric acid. Hydrochloric attacks metal so much it is hauled in rubber lined vessels! Naval Jelly is based on Phosphoric acid which is alot milder, read the label on your soda pop can, it is in there!
Old 12-24-2009, 08:49:42 PM
Temple2426 Temple2426 is offline
Images: 7
HAMMER!!!
12 Steps to free a stuck piston B Kedrowski Antique Gas Engine Discussion 45 10-18-2015 10:11:33 PM
How do you free a stuck 72 twin Matt McGivney Maytag Engine Collectibles 13 07-06-2008 12:09:55 AM
stuck valves 5hp fuller&johnson Jim Scott Antique Gas Engine Discussion 9 04-09-2005 11:37:48 PM
STUCK VALVES ihorse Antique Engine Archives 9 10-18-2004 03:38:23 PM
Stuck Valves JD Model E Stevie Antique Engine Archives 1 06-13-2003 11:28:42 PM
