Rusted Spark Plug
this thread has 10 replies and has been viewed 931 times
Old 09-29-2002, 08:17:32 PM
John Stewart
Default Rusted Spark Plug
I recently purchased an engine for parts, but I have enough other spares to make it whole again.
Only problem is that the spark plug is rusted pretty good (or bad) any ideas on getting it loose without damaging the head?
JS
Old 09-29-2002, 09:30:16 PM
Baggsy-Wy
Default Re: Rusted Spark Plug
Can you get the head off and into a tub? I'd give it a 12 hour dose of electrolysis. Worked wonders on a head I worked on awhile back...
Old 09-30-2002, 10:18:26 AM
Jim Sherman
Knock the porcelin out of it, grind down a hacksaw blade that will fit inside the plug and cut it out from inside of the hole. One releif cut may be enough if not put a second cut in and knock the piece out.
-jim
Old 09-30-2002, 12:07:54 PM
jd_mike
Patience and penetrating oil.
Old 09-30-2002, 02:36:24 PM
Dan Baalman
John I have done what Jim suggested and it worked fine. Dan
Old 09-30-2002, 09:23:19 PM
D. Smith
I agree with Baggsy , electolysis works wonders if you have a little time. Keep your anodes clean, let it work a couple of days, and it WILL come loose! D. Smith
Old 09-30-2002, 09:41:44 PM
Matt Sage
I Have had Great luck with heating the plug not the casting red hot with a torch.As it cools and the color goes away put some wax on it it seems to suck into the threads and provides a lube to help it out .Good luck...........Matt
Old 09-30-2002, 10:07:20 PM
Don C. Wiley
John;
I have had good luck spraying some penatrant around it and using a tight fitting socket, I just use a 1/2" air wrench and it has always worked for me. If that fails use the hack saw method or the torch.
"Your milage may vary"
"DELCO DON" Southern Illinois
Old 09-30-2002, 10:44:30 PM
BFultz
Delco Don.....I'm glad I'm not the only crazy one on this board. I've done that several times and it works.
Old 10-01-2002, 01:31:36 AM
Russ Hughes
When you said "an air wrench" did you mean an air driven impact wrench? These things sometimes work wonders with a little penetrating oil soaking in.
Old 10-01-2002, 09:21:34 PM
John Stewart
Thanks to all who replied...I got the plug out and all is well. I had been soaking it for a couple of months with no luck.
I decided to give the hack saw method a try. After I broke out the porcelin and removed that little screw in piece that holds the porcelin I thought I would give it one last try. It moved, and I was able to gradually work it out.
Now on to the stuck valves!
John
II Spark Plug For ??? Daniel Dorece Antique Gas Engine Discussion 4 12-28-2008 06:11:58 AM
spark plug Dennis Peters Antique Gas Engine Discussion 6 10-13-2006 11:30:47 AM
I.H.C. M 1 1/2 w/ Spark plug skylar Antique Engine Archives 1 04-09-2002 10:32:29 PM
spark plug jody smith Antique Engine Archives 7 07-19-2001 01:53:14 PM
JD spark plug Allen Heilner Antique Engine Archives 0 05-13-2001 06:09:56 PM
