Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
Multi-Cylinder Stationary Engines and Power Units Waukesha, Buda, Climax, LeRoi and others.
Waukesha FC 125 on Marlow pump ID help
this thread has 27 replies and has been viewed 3593 times
Old 12-25-2009, 11:00:11 AM
MIke D MIke D is offline
Default Waukesha FC 125 on Marlow pump ID help
Merry Christmas,
I just acquired an old Marlow pump w/ a Waukesha FC 125 on it. This unit is just about complete, missing side shrouds & aircleaner. All 5 data plates are legible. I've scoured the web & posts here looking for a S/N listing for date ranges & haven't been able to come up w/ any. I've seen references to code date & mfg date, but this doesn't seem clear looking at the s/n. The Wauk s/n is 473670 411.
I also don't see any dates on the casting or head. Any ID help would be greatly appreciated.
Mike
Old 12-25-2009, 11:36:24 AM
Default Re: Waukesha FC 125 on Marlow pump ID help
Have you contacted the Waukesha historical Society? They are all volunteers and it may take a couple of days for an answer. FC Waukesha engines were made over a rather long period of time.
Old 12-25-2009, 11:54:22 AM
Thanks John. I planned on doing that on Monday. I just picked it up last night & was looking for maybe a quick answer. The frame, wheels & pump castings kinda point me to the 30's. This is my 1st Wauk, so I'm not very familiar w/ the serial numbering conventions, etc.
Old 12-28-2009, 01:50:09 AM
Ed Malcom Ed Malcom is offline
Email Not Working
I have a unit that looks just like yours only it has a le roi d 140 engine on it. Ed the le roi man
Old 12-28-2009, 06:32:23 PM
Ed,
I did notice this unit has a Le Roi ground switch for the mag. Were they in cahoots??
Old 12-28-2009, 11:24:50 PM
Email Not Working
THAT COULD BE ANYBODYS GUESS. In that time frame there was lots of companies helping each other out/ lots more than today.
Old 01-04-2010, 10:38:41 PM
Jerry Sweet Jerry Sweet is offline
Thats a real early "FC",it still has a thermosyphon cooling system.I don't know when they started using a pump,but I think it was in the 1930s.
Old 01-04-2010, 10:55:46 PM
That looks like a "MJC" Bosch magneto,,but the ground (P lead) is comming out the side,it may a very early magneto.
Old 01-15-2010, 09:24:01 PM
Jerry,
After taking the intake/exhaust manifold off, I see a "12 1940" on the machined surface of the block & under the head crud there's a "7251940" small dataplate screwed on. So I say it was made in 1940, makes sense.
Onto the cooling system: I don't see a water pump, unless it's somehow under the front cover that drives the mag & gov, but it doesn't look like it. My question is: Should there be a thermostat in the head outlet? seems as though natural heat convection provides the flow, but a 180 degree 350 chevy thermostat will pop right in.I did the valves & carb, cylinders are nice & it runs good. I'm in the process of repairing the front rad shroud, then I'll pump some water. Did these have a thermostat? if so, what is a good operating temp? Thanks for the info & input.
Mike
Old 01-15-2010, 09:28:29 PM
Jerry,
The mag dataplate isn't legible. I cleaned the points & it's hot, firing what look like the original 6 Com Champs.
Mike
Old 01-15-2010, 11:11:34 PM
Mike: Doen,t use a thermostat on it,it's a thermosyphon circulating system(that's why it has such big water fittings and hoses)and a thermostat would just restrict the flow.A thermosyphon system will control it's own temp.If you use glycol antifreeze,be sure and mix it and the water before you put it in the engine,otherwise the glycol,being heavier, will go to the bottom and the engine may burn up ,because it will not circulate.The magneto is a American Bosch "MJC" base mount if you need to get parts or look up specs.The round plate on each side of the mag.should have big letters on them that read "AB".Good luck,Mike
Old 01-15-2010, 11:28:56 PM
Jerry,
Thanks for the info. I didn't know about glycol settling if it isn't mixed. I was gonna use 50/50 premix just like in the other stuff. Would that be an issue?
Old 01-15-2010, 11:44:42 PM
Mike:That should be fine.I would flush the system good,then check your fitting gaskets (make new gaskets if they look too old),replace the hoses,then use the 50/50.That looks like a real nice project ,Mike,good luck.
Old 01-16-2010, 12:01:25 AM
Jerry,
yes. I cut new gaskets, flushed, new hoses, etc. I should have the shroud done & cooling hooked up this week. I ran it dry for a couple minutes a couple times, I had to hear it run... The gas tank had a couple pin holes in it, all set now. The pump bearings took grease, I repacked the gland & cut new pump gaskets, impeller & case looks good. Should pump nice. I hope to take it to the Gas Up this spring. Here's a link:
http://www.youtube.com/watch?v=72sjXa4Mo4o
Here's a link to my Domestic Triplex:
http://www.youtube.com/watch?v=4nNKI-zHsw8
Old 02-04-2010, 09:35:45 PM
Larry Wolden Larry Wolden is offline
Jerry, I don't see a thermosiphon in the pic above. I have pics of a couple of Waukesha FC's with a casting along the top of the block that I understand to be the thermosiphon.
My FC has a three hole opening in the front of the head for a water pump, so it's obvious it takes a pump. My FC manual indicates, "The water pump is either head-mounted and belt-driven, or side-mounted and gear-driven." I don't know what the gear-driven pump looks like. Would you please point out the thermosiphon in the pic above?
Old 02-04-2010, 09:44:34 PM
Here is a pic of a Waukesha in a WC A-C. I was given to understand the long cast pipe parallel to the head was the thermosiphon. No?
Old 02-04-2010, 09:50:49 PM
Mike, would you mind posting a pic of the back end of yours similar to the view below? I have 2 PU's that are slightly different, and would like to compare to a third. THANKS!
Old 02-05-2010, 06:34:39 AM
Mike: A Vortex oil bath air filter bolts to the back side of the rear panel,where the hole is and a "S"shaped air tube goes from the filter(on the inside),down to the carburetor and connects to the carburetor with a hose.
Old 02-05-2010, 07:02:32 AM
Larry:A thermosyphon system isn't a thing,it is the way the coolant circulates.The heat from the engine expands the water(making it lighter,by volume).The hot water rises out through the hose to the radiator.The water cools in the radiator(making it heavier,by volume).The cooler water wants to go down and pulls the hot water behind it.That's why it circulates,why it's called thermosyphon,and why it has such big passages and hoses.
Old 02-05-2010, 07:10:12 AM
Larry:I forgot to tell you,thats a nice looking engine.I've never seen a Waukesha in a A.C.W.C. before,tell about it.
Waukesha 180 Joe Antique Gas Engine Discussion 1 12-31-2006 09:50:27 AM
Waukesha Gen set Mac Leod Generators & Motors General Discussion 0 11-13-2004 08:32:41 PM
Marlow water hog (mud pump) - need diaphram Christopher Winslow Antique Engine Archives 2 12-13-2001 01:26:00 AM
WAUKESHA Ronald Biggs Antique Engine Archives 0 12-11-2000 11:20:52 AM
waukesha 2 cyl. Ed Antique Engine Archives 3 12-05-2000 08:17:54 PM
