| Onan Generators Restoring, operating and maintaining vintage Onan generators. |
Onan 6.5 rv generatorI HAVE A ONAN 6.5 GENERATOR IN MY RV. MODEL NUMBER AND SERIAL NUMBER 6.5NH-3CR/16004P. IT IS IN A...this thread has 6 replies and has been viewed 4270 times
I HAVE A ONAN 6.5 GENERATOR IN MY RV. MODEL NUMBER AND SERIAL NUMBER 6.5NH-3CR/16004P. IT IS IN A 1985 CHEVY SUNCHASER MOTOR HOME.. I HAVE IT OUT FOR REPAIR.. IT WILL NOT TURN OVER.. IF YOU JUMP THE CELONOID IT WILL TURN OVER AND YOU HAVE TO GET FIRE TO THE COIL... THIS IS MY FIRST ONE TO WORK ON AND I AM TRYING TRIAL AND ERROR... I HOPE I ANSWERED ALL THE REQUIRED THINGS IN MY OPENING. I READ THE PLATE AS BEST I COULD.. I GOT CUMMINGS SOUTH TO TELL ME IT WAS PARTS BOOK 940-0360 AND SERVICE MANUEL 900-0337. I DUNNO IF THAT IS CORRECT... I NEED TO KNOW WHAT THE PLUG ON THE SIDE DOES... DOES IT ACTIVATE THE FUEL PUMP AND SWITCH...OR HOW DOES THIS WORK... I AM INTERESTED IN SELLING IT EVENTUALLY BT WANT TO CHECK IT OUT FIRST TO TELL ALL I KNOW AND BE TRUTHFUL. ALL THE WIRES LOOK GOOD AND IT CAN BE TURNED BY HAND SO I KNOW THE MOTOR IS FREE. WHEN I HAD IT TURNING OVER THE POINTS FIRED AND SO DID THE PLUGS... SOMEONE GIVE ME A STARTING POINT. YOU CAN EMAIL GSP974@HOTMAIL.COM .... NEED ANY INFO OWNERS MANUEL OR SERVICE MANUEL ETC... JUST GENERAL INFO... THANKS IN ADVANCE.....
Here's a link to your service manual:
http://www.esnips.com/doc/ab5cce39-5...Service-Manual Hope it helps. Steve |
The most common problem is bad start solenoid. You need to have the correct one. Sometimes people will buy one from a parts house that is wrong. They look just like Ford units but they are not. The one for yours is a 307-1617. The number should be on the back side of the solenoid. The white plug on the side is for a remote start control.
The engine requires fuel, air, and spark in order to run. If you have spark and air, you may have a fuel problem. You probably have an electric fuel pump - make sure it is running AND pumping (had one once that ran fine, but pumped nothing - a good cleaning fixed that - gummed-up check valves). There also may be a fuel cutoff solenoid in the fuel line - make sure it is opening. All this should be covered in the service manual. First thing is to get it to turn over, then make sure it has fuel, air, and spark.
If the unit has sat up for any length of time, the fuel can gum up the carb, fuel pump, etc. If your unit has a downdraft carb, you have to remove the intake manifold to get to the bolts that hold the carb to the manifold, so you can get the carb off to clean it. None of this is a lot of fun to do, but it's not too difficult if you have a bit of mechanical experience. The service manual that has been provided to you has a wealth of information, but it is intended for use by someone who is experienced with mechanical/electrical service procedures. Don't start taking things apart until you have done some diagnosis so as to know what to take apart. Dave Edmonds |
Hey i got it... Thanks for all the help... My brother came down and we tinkered with it for a few hours and man it runs like a top... Then i mounted it on an old grill base got me a hundred amp box ..... Wired it all up and man what a machine...used my grinder and a drill... Dont even break a sweat!!!! Thanks for all the help guys!!!!! I got the manuel too.... Now i dont really wanna get rid of it.... So unless someone gets off the hip... I will have it a while... Heck i dont even know what it would be worth and you sure couldn't ship it... Anyway have a great one...
![]() ![]() :d
The green paint seems to have addictive qualities.
We forgot to warn you first... Sorry, no cure! |
YOU WILL LAUGH AT MY RED NECK INVENTION BUT I TOOK IT PUT A BOARD OVER AN OLD GAS GRILL THAT I MADE A SMOKER OUT OF. THEN MOUNTED THE ONAN TO THE TOP OF IT. GOT ME A 100 AMP BRAKER BOX AND MOUNTED IT TO THE OLD GRILL BOTTOM. RAN ME A PLUG IN AND NOW WAHHH LAHHHH A PORTABLE GENERATOR.... I THINK I AM GOING TO JUST BUY ME A WELDER AND IF I GOT A JOB I NEED TO DO LOAD EM UP AND GET ER DONE!!!! STORES NICE AND NEAT IN THE CORNER OF MY SHOP....
![]() ![]() I CANNOT THANK YOU ALL ENOUGH... ANYONE NEAR GA.... LOOKING FOR THE NEXT PROJECT...
| Onan generator | robert dussault | Onan Generators | 0 | 02-20-2009 02:00 PM |
| Onan generator 25 ec | George Bernal | Onan Generators | 3 | 09-11-2008 02:33 AM |
| Onan Generator | Tom Marshall Jr. | Onan Generators | 6 | 08-23-2007 09:48 PM |
| Onan DPR and DPN generator | Applejack | Onan Generators | 2 | 05-25-2006 10:41 PM |
| Onan generator | Steve Dalley | Onan Generators | 2 | 02-19-2006 08:57 PM |
